So who here has had experience with them?
My car is booked in for dyno tuning next week and wanting to know if anyone has used them before, good/bad experiences.
So far very happy with the excellent level of service. I sent them an email yesterday morning and instead of one of those $hitty replies that you usually get from mechanics and such, Trent called me and took the time to speak to me for about 10 mins.
So anyone?
Cheers,
Steve
:P
https://www.sau.com.au/forums/topic/58873-mercury-motorsport/
So anyone?
Cheers,
Steve
:D
my car was there last week to get the PFC fitted and a few other minor things addressed, was happy with the results and service.
have since sent a email with a few questions about the PFC and Trent actually rang me back to discuss it. Happy with the service and happy with the results
Also saved 10% by being a member of SAU :rofl:
Regards,
Garry
Thanks for the feedback guys. Will let you all know how it goes next week. Hoping to end up getting more than ~250kms per tank and crack 200rwkw.
Cheers,
Steve
I was struggling to get 250 a tank before the PFC went in :D
power went up from 171rwkW to 192rwkW and first tank was over 350km :rofl:
and that was even plenty of 'fun' driving (it's amazing the difference 21kW can make to a torque curve)
I get 500kms to a tank and I get annoyed that thats it :P
Anyway, all my mates who have been there were REALLY happy with the service, and quality of work, and most of them are fussy barstards, so should be rite.
i had my fmic fitted there and then car dynoed as well...could not fault the quality of work and was very happy with the service. I work just down the road from there at another car dealership so it is very convenient where they are and they are a bunch of great blokes...trent and his staff. Would recommend to all.
Jason
I think they charge about 140/hr for tuning. SAU QLD members (paid) get a 10% discount so roughly 126/hr. Trent says that they should be able to fully retune mine in approx 3 and a half hours.
Dont know what they would charge for just a dyno run, if you mean you just want to get a horsepower figure?
Steve
You need some sort of aftermarket ecu either a full stand alone or a piggy back system. Piggy backs allow you to usually play with a/f ratios, ignition etc whereas stand alone allows you to change everything and anything and also usually have auxillary outputs to add things like intercooler spray or NOS.
Steve
Let us know how it goes steve cause im keen on getting a bit more poke and a bit better fuel saving....
Going from the old 31 i thought it was good at 350km per 63 litres with "major mods" to a almost standard r33 and getting 350km from roughlly the same fuel....
Suer Col. I get the car back this afternoon and Trent seems to think that i may get around 400kms/tank. Are you using the standard ecu? If so they tend to run rich. With my standard one i was getting about 300-350kms so your sounds about right to me. Ill post results later today with a/f ratio and rwhp. Hopefully get a dyno printout from them?
Steve
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
