Hey, im just wondering if anyone knows how to (easily) remove the perspex light covers on the front of an R33. Ive seen it done, but dont know how to do it. Just want to know if anyone has done it so im not in uncharted territory and somehow break it.
Any help is much appreciated.
https://www.sau.com.au/forums/topic/58911-r33-lights/
Hey mate, if you find out can you pls let me know??
https://www.sau.com.au/forums/topic/58911-r33-lights/#findComment-1128801
umm B1 just told you guys how to do it!
just remove the 4-6 clips off the clear outer section... then with a heat gun SLOWLY heat up the sealant holding the 2 pieces together....
then gently pry them apart, making sure you are extra careful at the parker light end as it has a tab holding it to the rear section of the lights..
then once you have removed it you will need to clean off all the old sealant with thinners and a rag ( long job) re-apply sikaflex to join and put back together!
any more specific questions... let us know :cheers:
https://www.sau.com.au/forums/topic/58911-r33-lights/#findComment-1137761
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
