hey guys i have got a half cut for sale r34 neo engine rb25det comes with engine loom gear box computer pritty much everything to make it run :P engine is in good condition pics will be up asap earily next week
RB25det neo 5speed manual
wanting 3.5k
0402670354 or [email protected]
if anything else is needed off the front cut dast front windscreen fron gaurds front strusts
post up or email :)
cheers guys
https://www.sau.com.au/forums/topic/58929-fs-r34-neo-engine-package-35k/
Are you going to convert an r33 to r34 ? what about the rear ? wouldn't it be better to sell the 33 and buy 34 , then you will have the real thing .
Thats what i'm in the procces of doing .
Anyway good luck with the conversion .
it is a 5 sp manual :cheers:
no i got a uras conversion kit for a r33 i am selling and i have found a hlaf cut to source out the parts depending on how much this front cut sells for with all the peices will deternian how much the nose conversion will be
you guys have all seen silvias and 180 have s15 nose's now you can upgrade the skyline ones with this kit it is very cheap considering the firs for r33 in australia :)
also would like to say radiator fan shourd everything will go with the engine if any one want front console dash steering wheel front seats i think inculed  plz post up or pm me a offer :(
Hi I have and NEO RB25DE.....will that engine be a straight swap?
  • 1 month later...
yes engine mounts will bolt straight up
Hi do you still have this engine available?
any pictures? i live in sydney, how can i get the engine if i decide to buy?
so the engine is complete? turbo, ECU, wiring loom etc?
Thanks
hey guys it has been some time since i posted in this thread as .... when i first made the thread there was no interest i will have to go cheak out the engine and see what bits have been taken off but it will be a slow process as i am busy and it takes 2 hours to drive down to the factory ... the uras kit may still be avalible
sigh:(
Could you tell me how the mounts and mounting points compare to the rb20det in r32 gtst's?
i have a rb20 in my 260z using stock mounting points - want more to happen when i use my right foot:).
You dont have to bother replying if you dont want to, i wouldn't be able to buy for a few weeks or months due to having to repair the few thousand dollars a theif cost me
  • 1 month later...
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
