hey guys i have got a half cut for sale r34 neo engine rb25det comes with engine loom gear box computer pritty much everything to make it run :P engine is in good condition pics will be up asap earily next week
RB25det neo 5speed manual
wanting 3.5k
0402670354 or [email protected]
if anything else is needed off the front cut dast front windscreen fron gaurds front strusts
post up or email :)
cheers guys
https://www.sau.com.au/forums/topic/58929-fs-r34-neo-engine-package-35k/
Are you going to convert an r33 to r34 ? what about the rear ? wouldn't it be better to sell the 33 and buy 34 , then you will have the real thing .
Thats what i'm in the procces of doing .
Anyway good luck with the conversion .
it is a 5 sp manual :cheers:
no i got a uras conversion kit for a r33 i am selling and i have found a hlaf cut to source out the parts depending on how much this front cut sells for with all the peices will deternian how much the nose conversion will be
you guys have all seen silvias and 180 have s15 nose's now you can upgrade the skyline ones with this kit it is very cheap considering the firs for r33 in australia :)
also would like to say radiator fan shourd everything will go with the engine if any one want front console dash steering wheel front seats i think inculed  plz post up or pm me a offer :(
Hi I have and NEO RB25DE.....will that engine be a straight swap?
  • 1 month later...
yes engine mounts will bolt straight up
Hi do you still have this engine available?
any pictures? i live in sydney, how can i get the engine if i decide to buy?
so the engine is complete? turbo, ECU, wiring loom etc?
Thanks
hey guys it has been some time since i posted in this thread as .... when i first made the thread there was no interest i will have to go cheak out the engine and see what bits have been taken off but it will be a slow process as i am busy and it takes 2 hours to drive down to the factory ... the uras kit may still be avalible
sigh:(
Could you tell me how the mounts and mounting points compare to the rb20det in r32 gtst's?
i have a rb20 in my 260z using stock mounting points - want more to happen when i use my right foot:).
You dont have to bother replying if you dont want to, i wouldn't be able to buy for a few weeks or months due to having to repair the few thousand dollars a theif cost me
  • 1 month later...
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
