Hi Guys,
Looking to do some work on the ole R32 GT-R 'zilla over the Christmas --> New Years break. Below is what I plan to do in terms of fluid flushes/changes, along with the fluid/oil.
I was wondering if people can give me an idea of just how much of each oil/fluid I will need for each of the jobs...? Also, recommendations are welcome :cheers::
Gearbox oil - Redline Lightweight Shockproof (~4 litres)
Transfer case oil - Dexron III compliant ATF (~2 litres)
Front Diff oil - ??? (~1 litre)
Back Diff oil - ??? (~1.5 litres)
Brake fluid - Motul DOT 5.1 Brake Fluid (??? litres)
Coolant - ???
Already done:
Power Steering Fluid - Castrol Transmax Z (~1 litre)
Engine Oil - Royal Purple (~7 litres)
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/58968-r32-gt-r-fluid-oil-flush/
Do you have a copy if the WS manual ??, all the amounts are given there. 7L for the engine oil ?? supposed to be about 4.5-5 depending on whether the filter is changed or not.
I've been trying to find out about what PS fluid to use - who recommended the Transmax (sounds like auto tranny fluid ??). The stuff recommended in the WS manual has never been available in Australia, apparently.
I use and recommend Penrite products :cheers:
Hi Guys,
I was wondering if people can give me an idea of just how much of each oil/fluid I will need for each of the jobs...?  Also, recommendations are welcome :):
Gearbox oil - Redline Lightweight Shockproof.
Transfer case oil - Redline Lightweight Shockproof.
Front Diff oil - Redline Lightweight Shockproof.
Back Diff oil - Redline Lightweight Shockproof.
Brake fluid - Motul DOT 5.1 Brake Fluid.
Coolant - ???
Already done:
Power Steering Fluid - Castrol Transmax Z (~1l)
Engine Oil - Royal Purple (~7l)
Cheers,
Lucien.
Hi SteveL,
I do have a copy of the WS manual, but I find its rather unhelpful, hence I was after people who have changed these oils to get a real idea of what I actually need.
It was a complete engine oil flush and filter change, not just a straight oil bleed + change, hence the rather high usage of oil (it may have been closer to six: I don't have the workshop receipt in front of me :cheers: ).
Transmax Z is a fully synthetic ATF but also explicitly states its designed for power-steering applications. I did a search on here and someone recommended it, so gave it a try. I found it extremely hard to bleed the power steering fluid (as I couldn't jack the car to get to a lead under the reservior), so I had to syphon it out of the top.
LW.
Aren't you suppose to use ATF in the transfer case not g/box oil?
:werd: not gear oil in the transfer case
and make sure before you open any drain plugs that you can open the filler plug first :cheers:
Re street use GTR V Spec II & N1 spec
Engine Oil - factory spec 7.5W-30/ 5W-30 5 - 5.3 litres
Manual Trans 75W-90 GL4. 4.1 litres
CastrolVMX is fine or Nissan mission oil BNR34 Special-although REDLINE do
a good oil, expensive.
Transfer prefer Nissanmatic D or can use dexron III 1.8 litres
Attessa Actuator- Gen Nissan Power Steer fluid 2 litres enough to
flush & bleed actuator system.( DON'T USE DEXRON OILS REFER NOTES BELOW)
Power steering (HICAS R32) Gen Nissan Power Steer fluid 2 litres enough
to flush & bleed actuator system.
Front diff .Hypoid gear oil GL-5 80W90 1.3 litres( for modified vehicles be sure it hasn't got front LSD Diff- if yes then use LSD GL5- 80W90)
Rear Diff.Hypoid gear oil LSD GL-5 80W90 1.6litres ( GTR spec 1.3 Litres)
1. Transfer case fluid
Nissan Matic D is strongly requested because high torque is applied to
transfer unit.
2.. Transfer case (ATTESA E-TS-PRO Actuator) : It is not acceptable to use
DEXRON III fluid.
> Only Nissan Power Steering Fluid Special use is required.
Today I received the technical information from our design department.
1. The difference between the DEXRON III and Nissan Power Steering Fluid
Special
The viscosity characteristic of Power Steering Fluid Special is lower than
that of ATF DEXRON III and the resistance to wear is also improved.
Each viscosity is the same level at 100 deg.C and the former viscosity is
designed to have the lower value for under 100 deg.C than the latter
viscosity.
This characteristic is aimed to rotate an oil pump located in ATTESA PRO
actuator easily at the extremely low temperature (Around -30 deg.C or -40
deg.C)
2. What will happen if a customer puts DEXRON II or DEXRON III into the
ATTESA PRO actuator reservoir in the trunk ?
The 4WD performance will be largely decreased at the low temperature
because the viscosity value of DEXRON II or III is extremely high compared
to that of Power Steering Fluid Special ;
As the rising characteristic of 4WD torque transfer becomes worse, it takes
the longer time to transfer the driving torque to the front wheels. There
is a possibility that the 4WD cannot be achieved in the worst case.
This may or may not be useful - straight out of the Australian delivered GTR32 owner's manual:
Recommended lubricants:
Fuel: Premium unleaded - min octane 95 RON
Engine: API SG 7.5-30 Turbo
Manual transmission: API GL-4 80W-90
Transfer case: Nissan Matic "D"
Power Steering Rack: Dexron II
Cooling System: Nissan LLC (long life coolant)
Brake and Clutch: DOT 4
Capacities:
Fuel: 72L
Coolant: 8.7L
Engine w filter: 4.6L
Engine w/out filter: 4.2L
Power Steering: 1L
transfer unit.
DEXRON III fluid.
Special
viscosity.
deg.C)
Please read
GTR V
GTR V: I fail to see how posting the same thing twice is of any great help.
I don't want to use Nissan OEM fluids. I know Matic D is an ATF fluid, which would suggest that ATF should be used in the transfer case and not straight gear oil. Is that the point your trying to make?
LW.
I think the the point he is trying to make is even though dont want to, its recommended to
use Nissanmatic D.
I'm sure people have used non nissan spec ATF before.
Then again theres probably a couple running around with shockproof in the transfer case
aswell!
I'm gonna do my soon, let us know if you find a better alternative.
yeah we run non nissan spec ATF.
No offence to redline but are they aware of how the gtr transfer case works or are they just guessing? It apparently very similar to an auto trans and does run the same fluid.
Hopefully someone has some exact numbers, but ATF is considerably thicker than regular gear oil, and is often used by the shonkey dealer to hide gearbox problems.
You must use atf ( dextron 3 ) in the transfer case , it holds just under 2 lts from memory fill to the filler hole ( until it runs out ).
Duncan the atf oil is thinner that gear oil .
Use gear oil; in the g/box 75-90 .
You can use lsd diff oil in both diffs , you cant use non lsd oil in lsd diffs .
Ok, so basically we have established Redline has no idea: glad I asked because a couple of people seem to have followed Redline's suggestions.....
So scratch Lightweight Shockproof for the transfer case (which is good, since it costs the earth). Does anyone have specific recommendations for a transfer case oil? Likewise for the diff oils? As I understand it the R32 GT-R runs an open front and mechanical rear diff: will the same oil be OK?
Cheers,
Lucien.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
