  • Replies 147
ok edit..
everyone i think money got alittle defences cuz he doesnt know bam like we do :) so he must have through maybe he isnt jking and took the replys from everyone the wrong way.
Sauwa members seem to have ago at the youngest members for abit but they are just playing around.....
mikey.... we still pick on u :boohoo:
and we are nice to all new members, don't take things personally it's just sometimes people say or type stupid things and most of the time people will take it the wrong way because thats how it has been expressed.....
TJ, thats true.... u have enlightened me oh wise one..... lol
adrian :)
hahahahahahahahah whats all this...
word of advice to Boost Monkey - dont take everthing u read on the forums seriously.. yeah some ppl on the forums will prolly stab you but im not one of them, regardless of what people say :)
ure new here so u gotta bear with all the insults and bullying like how Mikey does, its part of the 'initiation' process but its all in fun.. most of the guys on here are good blokes just dont be alone with TJ at any time in dark places and you should be ok.. also watch out for Niz's ass.. she'll rub it on ure head given the chance :S
all rite guyss...... CHILL!!!!!! i believe 99% of the users in this forum knows that bam isnt seriouss.... so take it easy man.....
and kiddo, i will be back in perth by the end of january, from the time i reach perth, i will have about a month before i start uni... so if ya want a ride.... just drop me a message.... be verry glad to bring ya for a spin......
Dannn, shhhhshhhhhhhhhhhhhhhhhhhh!!! hahahaha
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
