Take Me For A Spin ?
b00st_M0nK3Y
 Share
  • Replies 147
Something tells me you shouldn't say that stuff on here "Bam".
You might well get stabbed yourself.. k BamBam ?
Dude if you want people to take you for a ride in their cars, lose the attitude
the attitude is just Jase for you .... you get used to it after a while .... get past the attitude and he's not a bad kid a few stabbings should scare him straight :)
ok edit..
everyone i think money got alittle defences cuz he doesnt know bam like we do :) so he must have through maybe he isnt jking and took the replys from everyone the wrong way.
Sauwa members seem to have ago at the youngest members for abit but they are just playing around.....
mikey.... we still pick on u :boohoo:
and we are nice to all new members, don't take things personally it's just sometimes people say or type stupid things and most of the time people will take it the wrong way because thats how it has been expressed.....
TJ, thats true.... u have enlightened me oh wise one..... lol
adrian :)
hahahahahahahahah whats all this...
word of advice to Boost Monkey - dont take everthing u read on the forums seriously.. yeah some ppl on the forums will prolly stab you but im not one of them, regardless of what people say :)
ure new here so u gotta bear with all the insults and bullying like how Mikey does, its part of the 'initiation' process but its all in fun.. most of the guys on here are good blokes just dont be alone with TJ at any time in dark places and you should be ok.. also watch out for Niz's ass.. she'll rub it on ure head given the chance :S
all rite guyss...... CHILL!!!!!! i believe 99% of the users in this forum knows that bam isnt seriouss.... so take it easy man.....
and kiddo, i will be back in perth by the end of january, from the time i reach perth, i will have about a month before i start uni... so if ya want a ride.... just drop me a message.... be verry glad to bring ya for a spin......
Dannn, shhhhshhhhhhhhhhhhhhhhhhhh!!! hahahaha
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
