  • Replies 147
Well firstly.. That stuff shouldn't have even been posted, or left there.. It should of been deleted as it's completely off Topic... It isn't Whoretown Perth.
And I don't care if someone stabs me.. Call me tough boy I really don't care because they'll go to jail and get hammered.. Plus it wouldn't because your all nice and Nizmo would knock you out with her new FMIC
hi guy this thread become weird sound, hope you do not mind my input
is dsturbs wife a milfer?
remember the stranger danger when taking ride in fast car with old man :kick:
I can't stop pissing myself
And Boost monkey you have my name :headspin:
  • 1 month later...
b00st_M0nK3Y, What have the rides you been given, been like?
My r32 gts-t MODIFIED, will be on Fremantle docks, on the 11th and I’m expecting it to have some serious torque and Boost.
Well I got a ride in sileightys car, before I made this thread that was.. Crazy.
He has an RB20DET, like your R32 would have, and he had an exhaust a huge FMIC and an AFC I think.. Made 212hp or something like that in shootout..
Boost kicked ina bout 2.5k and you got hammered to the seat.
And last night when Mikey took me for a drive and asked me what it felt like, then he belted it, after we were off boost all I had to say was:
"Yeah, a bit like that."
But if your R32 is modified, trust me your adrenaline will be pumping.
Take me for a drive and I'll give you some comments =)
daym boost monky ur lucky go in 4 a ride in all thos cars
good 2 see im not the only 14 yo that likes imports
my mates allways rip the piss out me when the car topic comes up becuse there all
holden/ford pepole. my coolest expirience was a 1988 skyline doing a 20kph hand braky
planning 2 bie $500 skyline 4 p plates
KEEP IT ALIVE YALL!!!!
500 buckaroonies for a skyline ?
Mate, Doubt you can find one for that, even a 30 or 31...
But on the other hand, I hope you find one for that. I'm planning to Sil80 a cheap 180SX no matter what engine, cause I'm gonna RB20 it..
Anyway, Find someone with a skyline or silvia or something and get them to take you for a ride, and then you'll be addicted to boost.
iv seen heaps for around that price try ebay or the qukka all with little things like yellows 4 bald tyers saw 1 for $400 that needed a new head gasket me n ma dad can do all that sort o stuff u should b abel 2 keep it cheap if u can d.i.y
u should keep a eye on the qukka lots of parts engins etc maby even an RB20
lat8rs
na get something absolutly thrashed 4 a few 100 bukz then rebore it bie new pistons cylnder head etc put it back together all for half the price just diy and slightly more powerfull than brand new or find afollover with fooked body nd grab engin etc try the aoctions in perth they have some good deals
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
