Hi All, Just After Some Info On Suspension,when Buying A Set Of Say "tein" Height Adjustable Coilovers (secondhand From Japan) How Do U Know How To Check The Hardness Of The Ride They Will Give In Your Car Before Buying Them?? Bcoz Ive Heard Of Ppl Buying Them And Saying There Too Hard For Road Use, I Owuld Like To Maintain The Comfortable Ride As Much As Possible. Anyone Had Thiis Problem Or Know What Is The Best Way To Tell. Thanx 85urk.
i guess the only way to check the hardness is to whack it on the car if youve had no previous experience with coil overs. spring rates should give you an indication of how stiff the ride might be but u have to remember though different people have different definitions of "too hard" some think its too much others think its just right. a good starting point is to go for a ride with someone who has the same coilovers and springs that ur planing to buy. hope that helps
by the way, why does all ur words start with captial letters??LOL:D:D
i have just installed tein HA coilovers and i have to say i am happy with them...
the ride is harder than standard but not too bad for the road, but you do feel the bumps a bit more..the upside is the steering response and the handling has improved beyond my expectations..
i say go for them, if you dont like them you can always sell them.
I have Tein Adjustable coilovers. They are really ment for the track lol. Hard on the arse, and you feel every bump. Best handling though.
Note - stiff suspension does not a good handling car make...
common misconception amongst backyard 'tuners'. A combination of spring rates, damping, camber, castor, toe, and roll bars all together can make a car handle well.
Tien HA's are pretty good. They are hard, but not as bad as some. I would suggest getting rubber boots installed to protect them from getting rooted by the aussie conditions. They really wern't designed for australia, and they will get fudged up with dust and stuff, especially if you decided to tackle a dirt road...
They aren't as hard as say HKS hyper-d coilovers, but it really depends on what you define "hard"!!
They are definantly ok for road use, ie they are not racing/track only suspenison
True that,
Teins + Whiteline handling kit + strut brace = track setup :)
Awesome on the freeway and for tight cornering and handling but it sucks on shit roads which is pretty much everywhere :(
My car feels like a go kart, you steer it goes..
dont waste your time with teins unless you are doing track racing etc, if you are getting them just for road use see if you can get a brand of suspension that can be set soft or is soft. My teins are height/damper adj. and they are too hard. After a while of the lovely melbourne roads I soon popped both the rear shockers. Yeah on the freeway its elite but any of the other roads u feel every little crack and crevice in the road. Besides ur g/f's tits will get sore! As for JIC Magic...forget those they are mega hard. My mate had some on his r33 and with the windows down - when you drive over train tracks the window jumps about 2 inches out of the friggin door!
well that sounds painfully, im just after a comfortable ride but i dont want it crazy bouncy when you hit bumps, my mate has an s14 200sx and his suspension seems to stiff for my liking, when oyur coming down the road u can see the headlights bouncing up n down. i dont want that. also after a while of having too stiff suspension all your door cards and windows start to rattle and parts start to creak. no thanks i just want to find a happy medium that gives a smoother ride but will give better handling and cornering. only for road use too not for the track. (P.S. i dont know why all my words were in capitals weird stuff! lol)
hahaha :) My girlfriend used to complain of sore tits too! She use to say she'd need a sports bra just to ride in the car, I always though it was just cause she has lovely D-cup sized babylons! But maybe it was too hard... I installed some Tein HA's along with all Whiteline urethane bushes, and front and rear strut braces, and bigger rear sway bar and I thought the car was firm, but still bearable. I have to say though that I didn't do a lot of k's in the car (not a commuting car).
Richard
for those commenting on teins, especially used ones, you cant say "teins are hard" or "teins arent too bad" because there are a whole range of springs and valve rates available, and your never going to know what the original owner in japan built them for. I bought tein HA's and they were drift setup, ROCK hard. whereas ive ridden on other sets of HA's that were completely different. Theres no harm in trying them out and if you dont like them, sell them as mentioned above (as i did), because its funny that no matter how much is said about Jap coil-overs being no good for Aus roads, there is never a shortage of dudes willing to fork out the cash for a used set!!! You never know, you may like them.
The easiaest way to make an assessment of their firmness is the spring rate. If there was any logic used in the chosen shock rebound valving it will be matched to the spring rates. So if you know the spring rates, then the shock rates are pretty obvious.:rofl:
I've driven a Whiteline/bilstein setup R32.
I was very impressed with the way it handled. General balance and smoothness over bumps.
It felt almost like stock R32 suspension, I also didn't notice any body roll.
Very nice to drive.
I've driven a R33 with coil overs and wasn't impressed.
I used to own a VS V8 Commodore that had a Whiteline/Bilstein kit fitted.
It too also handled very nice but obviously not as nice as balanced as the line. :)
For street use I really don't think you can go past the whiteline setup.
My car is a 95% daily driver 5% trackday use. I'd say go Koni or bilstein from Whiteline setup, they're nice on the road firm without getting too harsh. May not be as calibre as the other stiff suspension aimed for the true track out there, but if you own only 1 car and use it the way I use mine, u'd be happy with Whiteline. I am.
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
