Hi guys,
about this whole TT business, what is the best turbo timer ?
Keep in mind all it has to do is idle the car, it's got to be affordable (reasonable quality)
It has to be small, the less noticable the better.
It seems like a pretty simple device, can I just jump on down to Jaycar and pick up a Kit one for $30 ? That way i'd only have a trimpot showing on the dash, and nothing more.
What TT do you all Have ?
-Kym
https://www.sau.com.au/forums/topic/5902-tt-recommendations/
Hey dude. I am thinking about giving my turbo-timer the heave ho. Not that it doesn't do the job, I just don't want to have a turbo timer anymore, I much prefer being with the car when it is running :-)
If you are interested, it is a Pivot Full-Auto Timer. I won't be removing it for a few weeks but when I do, it will be for sale.
Cheers
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89340
Cheers
cool, i wont need one for a few weeks anyway, was just doing preliminary research....
PM me when your ditching it :D
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89342
Guest GR33DyMANGO
Cheers
hey, yer i need to get a tt in about 2 weeks at the latest as i getting alarm put in before i get it registered in 2.5/3 weeks so it'll need to be installed at the same time.
how much would you sell it for? and is it in good condition?
thanks,
feel free to PM me.
justin.
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89344
If you're looking for the a small cheap reliable turbo timer, you can't go past the pivot item. I've got it in mine and it's barely noticable. Only $160 new from Xspeed but if you can get it second hand from HKS-S14, go for it!
My 2 cents (i don't charge GST)
:D
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89405
It would round down to 2c even if you did charge GST :(
.. My 2.2c :D
P.S. Those HKS Level 0 or 1 look cool, worth the money? (the more expensive one which does the qtr mile times and stuff) I think it's like $250 or something.
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89407
if u are after rice, hks type1 timer is nice, but really you don't need one, just use common sense and drive it soft for the last few km to let it cool down before switching it off. I wouldn't want to leave my car idling and walk away anyway, even with an alarm (sets itself off anyway with loud exhausts).
Chris.
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89409
I've got a razo one. Its fully automatic, just senses the RPM of the car and adjusts time accordingly. The alarm system (cyclops)I have arms itself partially as soon as I press the button and fully arms itself 10 seconds after the turbo timer stops the engine from running. I pretty much leave it set to 1 minute, cos the auto setting is a bit crap sometimes, if I've given it a really hard time I check the auto vs the 1 minute timer and see which is greater and leave it running. A turbo timer is more a convenience thing than anything else, but letting the turbo and engine cool down before shutting off is a MUST do.
Rob
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89524
I've had a really good run with HKS ones. There relatively cheap @ US$90 and have installed them in most mates cars.
You can install them yourself if you get the wiring harness that plugs straight into the existing connectors.
Has anyone tried the Cheater car alarm. Someone was saying they had an inbuilt TT.
https://www.sau.com.au/forums/topic/5902-tt-recommendations/#findComment-89909
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
