Decided to finally sell my car. Bit the bullet and I'm looking to buy a gtr with 2530's or n1's.
It a grey late 92 gtst type M with an rb26 fitted. Bit of a sleeper. Drags off commodores and falcons with the dirt bike on the trailer.
I'll try and get the car registerd with the 26 next week but if that doesn't work I'll put the 20 back in.
Mods:
RB26dett with good compression around 160psi all cylinders
R33gtr turbos
2 1/2 inch front pipes into 3 inch then into a 2 3/4 inch trust exhaust (very very quiet, cops never ever pull me over)
Mines CPU with suprisingly good timing and fuel maps for oz fuel
Adjustable cam gears
Tube and fin fmic 600x300x76
daiken heavy duty clutch. No need for a button. It won't slip.
Lightened flywheel about 5kg
Still got the rb20 g/box. If you speak to people in the know they seem to hold up pretty well if you treat them right.
Made 211 rwkw at ice at 6000rpm but the boost controller wouldn't hold boost past that and also without the cam gears ( should be around 230-240 now). The extra torque over an rb20 makes it a pleasure to drive around town. F all lag.
KYB Street Shocks
Stern 3 peice wheels 17 by 7.5 front and 8's on the rear with good tyres.
2xnismo lm gt4's 17 by 9.5 with 255's( wides rims you can fit under rear. MM's each side) worth around $850 each very nice and light rims.
Original GTR body kit
RB20det with a chipped cpu and r33 turbo and new timing belt.
Spare rb20det with turbo and stock ecu
Spare r32gtr turbo
Plus heaps of other spares
All in all a good reliable car that has never give me a problem
Looking for $19000 for everything and if it nobody is interested I'll be willing to sell the rb26 seperate since its probably worth around $5500 with everything and you can test it in the car. Do the maths and see what its worth to modify a car or buy one thats done. I'll try and get some pics soon.
https://www.sau.com.au/forums/topic/59031-r32-gtst-with-a-rb26dett/
sounds nice man...u interseted in a trade for a heavly modded brand new repsray 180?
pm me if intersted..Cheers Adam
i have told you about posting in the for sale area, you are dodgy and you are now banned.
Christian
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
