Fellas,
Yesterday was quite hot in melbourne and my engine temp reached 86c which is warmish but the car still ran fine... Today when i went to drive my car the idle is very irratic. when the engine is at operating tempreture the engines idle goes from around 900-1400rpm by itself... Constantly goes up and down. I have checked most of the electrical connections and most of my hose connections and yet and still have no cure....
Any help would be much appreciated
i have a 96 mdl r33 turbo manual with a Power FC computer
Cheers
https://www.sau.com.au/forums/topic/59049-idle-is-up-to-shit-help/
Hey mate,
Not sure whether i completely understand your problem, but it sounds like a similar problem I had... I suggest you check the harness running in2 the ECU, because that was my problem...
The RPM signal was cut, and re-soldered but a very average effort so when it got warm the wire's would expand then when it cooled it would only contact every so often so it would be unstable.
The wire colour is yellow with a blue strip running through it...
Hope this helps but not too sure because I'm not sure whether the harness was changed with the Apexi FC...
Goodluck mate,
Let me know how you go!
the problem seems to be related to engine temp... car idles fast when its cold because its on the cold start procedure, when the engine temp gets to 60c the engine note changes a little and as soon as it hits 68c the idle goes all funny.... from 1200-1600rpm.... up and down up and down constantly.... When I turn the car off and restart it straight away at operating tempreture the engine sits on 2000rpm for around 5 seconds and the drops to 1200rpm and revs up to 1600rpm up and down.... Its really giving me the sits...
It didnt do it yesterday but today i did.... Very very strange
Make sure that you have a fully functioning genuine Nissan Thermostat.
Rated at 76.5degC (stamped on it) $30 from Nissan if thats the problem.
The thermostat is designed to commence opening at 76.5degC and be fully open at approx 90degC.
So yeah, the temp should be within this mark when at operating temperature.
Also with age the Clutch Fan can be engadged all the time, and not allowing the motor to warm up properly.
The clutch centre is viscous type, and should only tighten up when its warm.
And the last thing, make sure the guage is right that you have the temp reading from.
Does it use an independant sensor or is it piggybacked to the factory sensor?
If its piggybacked you can get wrong readings.
I would consider 86-92degC normal operating temp for these motors.
86 cruising
92 idle with air-con on + hot day.
If its way lower than that, you are going to get bad economy and accelerated engine wear.
Is that for a RB25det only? because my R32 RB20det sits on 78degC for normal driving and the highest ever temp was 86degC in stinking hot heat with a full car load.
Thats a general rule of thumb for most motors.
78degC sounds preety fine to me.
I mean if it were lower than the thermastat temperature then it would be a problem.
i.e If you said it was running at 50degC all the time, then there would be a problem.
  • 3 weeks later...
Try cleaning the AAC valve. Check the TPS throttle-closed position.
sorry to dig up the thread again but I have been having issues with idle lately also.
Each time I disengage a gear and return to neutral, ie when stopping my revs seem to jump up a couple of hundred rpm. I have pulled apart and cleaned out the AAC Valve numerous times in the last 12 months so it must be something else, any ideas?
Where should the TPS position be when closed? Is there a general rule like TDC or something?
Thanks
Dale
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
