I recently had a bosch 044 mounted intank on my GTR and are having a few problems.
Firstly sometimes the car has trouble starting sometimes, mechanic said its probably because the pump is alot bigger and needs to be primed to get some fuel into it first, is this normal or has he screwed up the install?
And just recently it sometimes hunts on idle, this may not be the bosch but I also had 700cc sards fitted a few weeks after and I think I remember someone saying cars sometimes has problems idling with these injectors.
Before anyone says it I know its an external pump and probably shouldnt be mounted intank but a dozen other people have done it..
Thanks
Did he use the factory nissan wiring?
You're supposed to use the factory wires to switch a relay and use a direct power supply from the battery instead - the pump draws too much power for the factory wiring to handle. At idle the pump might not be supplying enough fuel as it hasn't got enough power.
I am about to install a 044 in my tank. My research has shown that it needs its own wiring from the battery as stated by gtst25. It is rated at 15amps. Also when switching a seperate relay from the factory wiring make sure you attach the ground to the chasis and not the ground return from the factory wiring. The factory has a two speed controller which switches resistors into the ground line.
i installed a 044 into my gtst the other week and have had no problems at all. starts fine etc... must have stuffed up the install
LOL now go back and do it again, properly this time.
Midnight;
I agree it's worth checking the wiring.
I take it you have had the ecu tuned for the 700s ?
Regards
I've got a power fc and I've also fitted bigger injectors (not sard but nismo).
On cold start it never starts first go. Have no idea why but I have not touched my pump (Im told its aftermarket but I have no idea what it is). This has only been occurring since the FC has been installed. Once it does start though excessive amounts of black "fuel" smoke leaves the exhaust.
Is yours doing this? Maybe we have the same problem?
Would say you havent fitted a 1 way valve at the pump to stop the fuel from draining back, leaves heaps of air in the line, hence long prime times.
EDIT: Actually didnt read that it was intank... above doesnt really apply. Oops.
Also if you suspect its a priming problem you can test it, in between ON and START position on ignition it will fire fuel pump but not crank. Try holding it in this position (you'll hear the pump relay click over) for 5-10seconds before starting and see what happens.
mine does the same sought of thing, it occasionally hunts on idle and often stalls, ive got an external pump fed by the original pump through a swirl pot. std injectors and computer for now (got it from japan not long ago, havent caught up with cashflow to get power fc) the wiring and install is spot on, own wires from battery through a relay. it also needs to be primed up sometimes. sometimes it wont start at all first go, let it prime and it starts fine, other times it goes first go.
i havent really worried about it as i expected it to do it, aswell as chew through fuel under WOT.
cheers
Linton
It appears my fuel pump has gone to shit, i got 300k's from my last tank :( Usually get about 550 :thumbsup:
OK I give up. If the fuel pumps has "gone to shit" then it pumps less fuel, so you would get better fuel economy. :confused:
I got an 044 in tank in my GTR as well.
As has been suggested already - no check valve I would assume, same as mine. I got the same injectors & PFC as well. Mine starts perfectly but I gotta prime it a couple of times to get the fuel through.
No big deal really - just gotta remember to do it. Note that it is worse in hot weather.
As for hunting on idle - definately sounds like tuning as mine idles perfectly:D
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
