Hi Every-one
My Car It A R32 Gts-t Coupe.
I Am Having A Problem With My Hicas System,once I Start The Car Every-thing Is Fine And The Power Steering Is Normal, About 15 Min After I Start The Car And Drive Down The Road The Steering Becomes Heavy About Half Way Between Power Steer And No Power Steer,then The Hicas Dash Light Comes On About 5 Min Later.
Can Anyone Help Me Please With An Answer As To How To Repair It?
Thanks Stuart
https://www.sau.com.au/forums/topic/59074-r32-hicas-fault/
wrong section dude!
However do the HICAS diagnostic test. start the car, turn the steering wheel 45 degrees left and right 5 times or more then stamp the brake pedal 5 times.
the HICAS light will come on and you follow the flashes. Go to the tech section and it will give you the fault listings for the HICAS shit.
https://www.sau.com.au/forums/topic/59074-r32-hicas-fault/#findComment-1129110
