I was reading an article today that said Nissan Australia has registered the trademark "Infiniti GT-R".
Has anyone else heard this? is it WTY or WTLW? :wassup:
Article is mainly about the probabiltiy of it going to the USA as it will be produced in LHD form (apparently Ghosn himself said this???). It also maintains the engine will be a VQxxDETT probably a 30 or even a 32. Says it's the same engine being used in the 350z JTC cars???
ATTESSA will be present as will round tail lights.
I can see the Infiniti brand being used in the USA but it's interesting to hear that it may be introduced in Oz. I guess Nissan want to take on Toyota/Lexus.
https://www.sau.com.au/forums/topic/59077-infiniti-gt-r/
Yeah, I think on Performance Forums a guy posted up the site where the Infinity name was registered in AU... why would they do that if there was absolutely no possibility of the next GT-R being imported to AU? Anyones guess, but this is pretty old news, at least 6 - 8 months old.
https://www.sau.com.au/forums/topic/59077-infiniti-gt-r/#findComment-1128879
Skyline GT-R has been a registered trademark of Nissan in Australia since 1990, so I'm guessing they didn't have to re-register it. I think they're just covering their bases.
https://www.sau.com.au/forums/topic/59077-infiniti-gt-r/#findComment-1130637
  • 4 weeks later...
I did a search with the united states patent and trademark office and found the following results of interest:
you can search yourself here: http://tess2.uspto.gov/bin/gate.exe?f=logi...nglish&p_d=trmk
http://tarr.uspto.gov/servlet/tarr?regser=...&entry=76381543
NISSAN GTR
Filed on March 12, 2002
(APPLICANT) NISSAN JIDOSHA KABUSHIKI KAISHA TA Nissan Motor Co., Ltd
Why would nissan file for "nissan GTR" in the US in 2002?
they also filed for an extension on 08-10-2004
I found another request also made on March 12 2002 for "nissan GTR" in australia
http://pericles.ipaustralia.gov.au/atmoss/...m_number=905985
However what puzzles me is that in australia they also registered "Infiniti GTR"
http://pericles.ipaustralia.gov.au/atmoss/..._number=1005792
and the UK
http://webdb1.patent.gov.uk/RightSite/form...himnum=E3875507
but not in the US?
On a side note "infiniti R spec" is filed by nissan on DEC 10, 2002 meaning that we can expect the R SPEC parts talked about in the 2001 press release quoted below.
http://tarr.uspto.gov/servlet/tarr?regser=...&entry=76476233
registered logo:
NISMO branded parts will cover three areas - NISMO Performance Parts, designed for Nissan vehicles; Infiniti R-Spec performance parts designed for Infiniti vehicles; and NISMO racing parts designed for off-road/race-track use. NISMO also will offer performance parts for current and previous model Nissan and Infiniti vehicles, including the Sentra SE-R and the forthcoming Infinti G35 and Nissan 350Z.
https://www.sau.com.au/forums/topic/59077-infiniti-gt-r/#findComment-1163595
most likley just a safe guard so no little smart arse goes and takes the rights to the name from them, not a bad idea if you wanted to make a little cash when nissan did release that model??
well all it sya is Nissan GTR no model is specified so it could apply to any nissan GTR, I don't think anyone could register the name and get away with it look at www.nissan.com they sued that guy, so I'm sure if anyone tried to steal the name they could have some kind of legal action against them.
https://www.sau.com.au/forums/topic/59077-infiniti-gt-r/#findComment-1164012
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
