Got car dynoed, i knew it!
joh21m
 Share
Well as the title says i got my car on the dyno after suspecting it wasnt running as hard as it should....mods are as follows:
S13 RB20DET
Full 3" Exhaust
Nippon Denso f/pump
POD
FMIC
~11psi
what can i say, power is no where near what it should be! after only just keeping up with a ca18det sil i knew something was up.
Mechanic says all 6 coil packs are failing at once hence the power drop...
he says it should keep climbing to about 140 - 150kw once i get them replaced...
just thought id share it with you ppl, all comments welcome
Joh
my god... didn't you hear the aweful popping?!
there is no popping thats the thing, i could only feel that big dip so i knew it had to be something...
Whats with the big arse dip? dud coils would have had your car missing all the way to redline, i wouldn't have expected power to pick back up again that high in the rev range.
i also thought that if it were the coils it would be missing all through the rev range, i must admit it isnt a very smooth curve so then it leads me to think maybe it is the coils playing up??? i dunno, i dont wanna fork out $600 odd just to find out its something else... but the mechanic says its the coils
anybody else think it might not be coils?
11psi I think you will see 130-140rwkw.
15psi with stock fueling see's around 155rwkw, sort out the fueling and you then see around 165rwkw. Replace the ecu and you will see just over 170rwkw.
Get an RB25 turbo and you should get close to 185rwkw.
I would have thought 15psi and the exhaust wheel ends up sitting in the cat...
when you say sort out the fueling what do you mean? injectors? i already got a fuel pump...could you please elaborate?
i plan on a remap and rb25 turbo later down the track....
  • 2 months later...
just for reference for all i have found the problem...
turned out one of my knock sensors was not plugged in!!! car now runs extremely smooth (feels like a diff engine). getting it dynoed again on sat for a quick tune...
KEYWORDS - Knock sensor, 5500rpm, power loss...
good stuff.. shows how clueless the workshops can often be..
they'll always blame the coilpacks before anything else..
There should be a problem shoot flow diagram on here .. could save a lot of people headaches.
Hmmm originally i thought I had dodgy coil packs... believe i still might, however my popping and loss of power on full throttle only seems to be intermitant... usually on very hot days... just wondering if anyone might have any other suggestions besides coilpacks?
 Share
    • this explains the possibility of several maps with different boost levels
    • ok, I understand much better how we can control the boost and increase the number of psi before opening the wastegate
    • Well.... yes and perhaps no. It depends on what you mean by "spool". For most of us, the point that we would describe as where the turbo is "spooling" is the point where the wheel speed gets high enough for it to start making some boost. This is coincidentally around about the point where it starts making noise - hence the "spooling" sound. If that is what you mean, then no - the wastegate should still be shut at this point. The boost will still be way below the point where it should start opening. If, on the other hand, you mean "spool" as "reach full boost", then yes. At the point where the boost has reached target, then boost control has already started. The wastegate is already open, and has been for some time. Some short time, definitely, but still, some time. If you have no boost controller - just the wastegate actuator connected to the boost source, then you have a mechanical system working as a pressure balance. There is pressure on one side of the wastegate actuator's diaphragm from the spring, and pressure on the other side coming from the boost measurement location (the "source"). This is not a digital thing. The wastegate does not stay shut until the boost pressure reaches the spring "pressure". The spring will start to compress as soon as you start to apply any pressure onto it. This can be controlled somewhat by adding pre-load into the spring, but you cannot add enough preload to make it into a digital switch behaviour. The wastegate will crack open and start to leak exhaust out (and therefore not though the turbine) well before you reach the target boost pressure. Electronic (and some mechanical/pneumatic) boost controllers will act to prevent the boost source applying pressure to the actuator until just before you reach target boost, thus preventing the wastegate from creeping open. And some boost controllers will apply boost pressure on the spring side to further push it shut. And this can be be necessary because the exhaust pressure in the manifold also pushes on the wastegate valve and tries to open it and you cab get it leaking even without it being connected to the boost source.
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
