This will be useful if you need to replace your side mirrors, say if the glass gets smashed, or if you are doing your own compliance and need to change to flat from concave...
Its fairly simple and should only take 10 mins anyhow, but saves you having to think about it :)
First of all get the whole mirror assembly off the car. You may not have to actually, but it makes the process much easier. To do this you'll have to remove the door trim (remove pull handle screws, remove all screws around base and sides, pop off trim popouts, slide up).. After that if you have the plastic sheeting over the door wiring still in place, you'll have to carefully peel that back.
You should see where the mirror plug comes into the door and goes to the switch. Carefully remove the plug. There are 3 x 10mm bolts that hold the mirror to the door. Undo these, making sure to hold the mirror whilst doing it, so you don't drop it.
Now you should have it off... take it somewhere to a nice workbench, in front of tv, etc :) Look underneath the actual mirror part, and you should see a single screw. Thankfully Nissan has made it nice and easy to just get to the glass. Undo this screw, and you should be able to pull the actual part that adjusts the mirror the different angles.
Now that you can pull that out slightly, you should see the extra white plug that allows you to get this part out. Carefully press on the plug, and it should come off, allowing you to remove it from the main surround
Now you should have the actual glass part, and the backing plate separate. Flip it over, and you should see about 5 clips holding a sub bracket, which sits inside the actual glass holding bit. Use a long flat head screwdriver, and gradually prize it off, applying only a bit of force. Do this for each side and eventually this part will come off.
So now you should just have the mirror in the rubber grip which holds in place.. but you still need to get to the glass out by itself.
This probably best to do on a warmer day, or get out the g/f's hairdryer and use it to heat the back - as you will find there is some sticky chewing gum type adhesive on the back of the glass.
You should now be able to see the back of the glass so again, using the flathead, very carefully apply pressure to the glass. I found it easiest to apply pressure to different sides equally, and eventually it will slip out, maybe twisting the rubber a bit to help it on its way.
Bingo! You should now just have the mirrored glass on its own as one piece. Take it down to your local glass cutter and get them to cut out the same sized piece of glass.. and replace everything in the reverse process of removal!
All done. Easy as you like.. :headspin:
https://www.sau.com.au/forums/topic/59085-r32-replacing-side-mirror-glass/
I think its only about $30 or something like that to get it cut. Just take it to an industrial glass or mirrors place (it will be listed in the yellowpages). Haven't actually done that yet :P When I found out how much it costs, I'll post it here.
Well its just mirrored glass.. the same sort of stuff your wall mirror, vanity mirror, etc is made of.
Well done tutorial
When I did mine I didnt take the whole mirror out
One screw directly under the mirror and the the whole lot pops out.
undo the connectors and its out.
Just remember to take the backing plate to the glaziers as well, as mine needed grinding back for clearance.(they didnt have mirror the same thickness)
  • 3 weeks later...
update: just got the glass replaced today..
Only cost $15 from a glass place up here. As the stock stuff is thinner that what you'll usually find around, they may have to use the thicker 3mm stuff - but that will fit.
Yes, as Just says, you will probably need to take the backing plate so they can fit it in properly. For the $15 and they bonded it in there and everything.
  • 2 months later...
Even easier way,
There is a screw under each mirror that releases the electric motor to move the mirrors once this is release the mirror just pops out, and then get a screw driver and pop it out from its mounting points..
All good and takes 60 seconds.
My car is R32 GTS-t
  • Like 1
  • 5 years later...
Guys,
Just putting it out there, especially if you have a level of intellect not so dissimilar to myself... :wub:
If you undo that single screw that sits under the mirror and locks in the mounting plate, the spring is compressed by the screw.
In laymens terms, it goes: Mounting plate > white half bulb, flat side facing you > spring, screw.
I know, laugh all you like - but it had me stumped hahaha.
Cheers,
Steve.
  • 5 months later...
R33 is the same. The trick is you have get the mirror off [out of the mold it sits in] to see the screw. If the mirror is broken then you have no problem but if you are like me and only trying to remount the mirror because the last person who did it made a botch of it then you have to heat the mirror up - this softens the adhesive that is holding it on and then you can carefully pry the glass away without breaking it.
I cleaned mine up, a final wipe with Metho, reafixed the mold to the housing with the screw and then used some windscreen silastic and set the mirror back into the mold.
But I wouldn't have known how without Predators tutorial....thanks for that.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
