A few people have posted a thread on this but there a heaps of people that musnt have found it.
This is the diagnostic guide for skyline owners (most of em anyway)
For most people this guide should give you a good indication of what is going wrong according to your stock ecu
i did the test on mine and it came back with an error code of 12 which is the afm i replaced it and it now runs like brand new.
give it a go before you pay someone else to TRY and do it and save yourself some money.
This particular one was posted by Skyline_Boy
and i am not trying get praise for following up on his thread i am simply bringing it to everyones attention so here it is aswell, It can also be found in the diy section of the site.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=35733
this includes small diagram for mode changing
Hope this will tell you whats wrong with your car.
ECCS has 5 modes :
Mode 1 - Exhaust Gas Sensor monitor.
When the engine is warm (closed loop) the green led turns on for lean, off for rich. It should alternate. When it is cold (open loop) it will be either on or off.
Mode 2 - Mixture ratio feedback control monitor.
During closed loop operation the red led should turn on and off simultaneously with the green led when the mixture is controlled within the specified values. During open loop the red led stays on or off.
Mode 3 - Self Diagnosis. See below
Mode 4 - Switches On/Off diagnosis.
The inspection lamp monitors the idle switch portion of the throttle valve switch, the starter switch, vehicle speed sensor an other switches with an on/off condition.
Mode 5 - Real Time diagnosis.
Same as Mode 3, but it flashes the errors as they occur.
To select the various modes :
for picture of way to select modes
With the ignition ON take a small screwdriver and turn it clockwise. the LED's will flash together, first once, then pause, then twice, then pause, then three times. When this happens turn the screwdriver counter clockwise. The ECU is now in mode 3 which reads out the fault codes on the LED's. It will cycle through all stored fault codes.
Red LED = 10
Green = 1
some computers only have 1 red led but the principle is the same
If the red led flashes 4 times and the green one flashes 5 times that means you have code 45. It will repeat this if this is the only fault. If there are more faults it will flash all the faults and repeat.
The ECU will reset when you turn the ignition off.
11 - Crank Angle Sensor/Camshaft Position Sensor
12 - Air Flow Meter
13 - Engine Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal
22 - Fuel Pump
23 - Idle Switch
24 - Throttle Valve Switch
25 - Idle Speed Control Valve
26 - Boost Pressure Sensor
27 -
28 - Cooling Fan Circuit
29 -
30 -
31 - ECM
32 - EGR Function
33 - Heated Oxygen Sensor
34 - Knock Sensor
35 - Exhaust Gas Temperature Sensor
36 - EGR Control-Back Pressure Transducer
37 - Knock Sensor
38 - Right hand bank Closed Loop (B2)
41 - Intake Air Temperature Sensor
42 - Fuel Temperature Sensor
43 - Throttle Position Sensor
45 - Injector Leak
47 - Crankshaft Position Sensor
51 - Injector Circuit
53 - Oxygen Sensor
54 - A/T Control
55 - No Malfunction
63 - No. 6 Cylinder Misfire
64 - No. 5 Cylinder Misfire
65 - No. 4 Cylinder Misfire
66 - No. 3 Cylinder Misfire
67 - No. 2 Cylinder Misfire
68 - No. 1 Cylinder Misfire
71 - Random Misfire
72 - TWC Function right hand bank
76 - Fuel Injection System Function right hand bank
77 - Rear Heated Oxygen Sensor Circuit
82 - Crankshaft Position Sensor
84 - Automatic Transmission Diagnostic Communication Line
87 - Canister Control Solenoid Valve Circuit
91 - Front Heated Oxygen Sensor Heater Circuit right hand bank
94 - TCC Solenoid Valve
95 - Crank Position Cog
98 - Engine Coolant Temperature Sensor
101 - Front Heated Oxygen Sensor Heater Circuit right hand bank
103 - Park/Neutral Position Switch Circuit
105 - EGR and EGR Canister Control Solenoid Valve Circuit
108 - Canister Purge Control Valve Circuit
111 - Inhibitor Switch
112 - Automatic Transmission Speed Sensor
113 - Automatic Transmission 1st Signal
114 - Automatic Transmission 2nd Signal
115 - Automatic Transmission 3rd Signal
116 - Automatic Transmission 4th Signal
118 - Automatic Transmission Shift Solenoid Valve A
121 - Automatic Transmission Shift Solenoid Valve B
123 - Automatic Transmission Overrun Clutch Solenoid Valve
124 - Automatic Transmission TOR Conv Solenoid Valve
125 - Automatic Transmission Line Pressure Solenoid
126 - Automatic Transmission Throttle Position Sensor
127 - Automatic Transmission Engine Speed Signal
128 - Automatic Transmission Fluid Temperature Sensor
there is either a seethrough or metalic silver sticker on a side of your computer.
peel the sticker off which will expose either 1 or 2 lights and a small encased dial which can be manipulated with a philips head screwdriver.
with your led display you may have 1 light or 2 either one it is still easy to read.
then follow the above instructions
if you do have 1 led there is a definate pause between a 10 unit readout and the 1 unit readout
hope i helped
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
