  • Replies 86
Just spoke with ivan @ speedworks. He's more than happy for you guys to come to him for $50/person to have a power run on his dyno. Depending on numbers, might be able to get a couple of runs. I'd be pretty interested to see what numbers my car is up to now. I was up to 160HP @ wheels just after fitting an exhaust (stock airbox still etc). I'm sure it'll be over 200HP @ wheels.
Rob
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89527
Guest Autoworx
Streetforce in Wangara have just got a new Dyno and only charge $55 inc GST for a power run including printout. They are located next to me a Unit 3/38 Baretta Rd. They also manufacture and fit front mount intercoolers, 3" mandrel exhausts, air filters, bleed valves etc. They have already fitted heaps of mods to cars I've sold to customers so I can vouch for their price and quality.
Call Jason on 9408 3018 for quotes or pop in. You can check out our Skylines in stock & body kits at the same time
Paul
Autoworx
www.perthcars.com
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89535
mid december mid december!
stuff any later off :uh-huh:
whats wrong with mackas car? mid december macka - be ready :D
dunno what they usually cost, but do they tweak it a bit? or is a power-run just a read-out? if it's just a read-out, I'd be inclined to pay 20 or 30 as greg said
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89555
Ok, I'll talk to ivan again. If you want $30/car we are going to need to get a fair amount of people. When I rang PSI (about 6 months ago) to get a price on a dyno run (ie: run car with stock everything and then fit exhaust and run car again) I got quoted $100+ for the dyno time.
Rob
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89642
Hey Miko!
Last time you helped organise the dyno day it only cost about $25 at PSI. Maybe you could have a chat to Brett?
I think it would be good to use the PSI dyno again as most of us used this one last time. And as we all know the dyno is really best used as a refference (before and after) not as an absolute.
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89742
Yu[p,
I'm in the same state of mind as everyone else here... $50 is over the top, however a big thanks has to go to you for at least trying organise something like this! GREAT IDEA! Hey Summoner, the last Rollaboyz dyno day that i saw your car at when youwere tlaking to my bro i think he said it was only $30 that was at Melville i think???
Yeah i will be speaking to Brett@PSI sometime this week and should be able to get us a nice deal for a dyno day.... i guess the more numbers the better kinda thing... will this be on a saturday or a sunday guys?
Also PSI got their new dyno about 4 weeks ago! VERY NICE!!
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89783
any 2 wheel dyno is out if any of the GTR boys and girls want to come.
so that doesn't leave much of an option.
PSI's is 4wd theres a couple more around but i'm not sure where.
$100 at PSI is for tuning not just a power run.
power runs are usually the $50 mark.
Dyno days tend to be about $30 per car. but u need decent numbers atleast 15-20 cars.
adam nothing wrong with using PSI for a dyno day.
work on my car has been fine no problems others we know the story. i just don't go there anymore because of his stupid wife. Accused me of trying to ruin there business when they were broken into and she tried to get Kylie fired from her job.
https://www.sau.com.au/forums/topic/5910-dyno-days-r-us/#findComment-89911
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
