mp3 head units
  • Replies 48
Yeah just went to JB they had the JVC-S985 for $489. I asked can you do it cheaper. He said $450. I said well you had it for $400 before Xmas (Had no idea if this was true, heh).... then he goes alright $430. And I took it! $60 off and $110 of RRP aint bad for this unit.
Also I was also looking at the next model up the one with the flashy screen and all that bs and he said it wont be as good cause it only outputs 2V preamp whereas the 985 does 4V. Can someone tell me what the difference would be?
Does it mean the amp doesn't have to amplify as much sound?
it means that the RCA level out is carried to the amplifier at 4Volts rather than 2V. Alot of people purchase an Eq (usually about 7Volts) or a Line Driver which does the same thing. The better you get your sound to the amp the better sound you are going to get out... less signal loss=better quality sound.
by the way the salesman failed to mention that the KD-LH2000 (cool graphics) has a 24bit DAC (Digital Audio Converter) this is the highest quality audio converter on the market!!! i notice the difference, some ppls don't. :D
If you go direct to Hagemeyer (the Aust Agent for JVC) you can buy what they call "repacks". My bud has bought a few JVC decks and his current one is an mp3 deck. He paid about $200, in the box, unmarked with all docs & full factory warranty. Hagemeyer are in Alexandria (Sydney) I think.
ACtually the 985 has 24bit DAC as well. Well thats what the box says anyways ;)
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
