Guest two.06l
as the title says my rb20 standard turbo has started to make a whining noise? any ideas as to what has happened to make it do this?
cheers Matt.....
if it sounds like a siren, but not as loud. Your centre bearing has failed causing the compressor wheel to rub the inside of the housing. Result....a rebuild for your turbo.Paul...DIRTgarage.
https://www.sau.com.au/forums/topic/59197-whining-turbo/#findComment-1131232
okay lets not freak this guy out !
a whinning sound is nufin mine whinnes loud it sounds mad , its boostin good makes good power.
my whinning T28 has been on and off the car on numerous occasions it has been checked once off the car and its fine... drive it untill it goes thats my theory plenty of ppl had same issue with R32 T28 they can continue lasting its alright............................i have been through hell n bak with my engine down heaps to it but the only advice which i could give but which i never listen to altho i should is DONT FIX NUTTING UNLESS IS FAULTY
https://www.sau.com.au/forums/topic/59197-whining-turbo/#findComment-1133625
