Wrecked... Again.
azron
 Share
Just saw the morning news and 'another Nissan Skyline' has had a crash in Sydneys West killing the 21 year old driver and its 20 yo female passenger instantly.
Dont know who it was but, it was a green R32, looked like a GTR, same sort of styled rims, but i couldn't tell.
Rest In Peace buddy.
  • Replies 71
Pair die in crash
08:45 AEDT Tue Dec 21 2004
A young P-plate driver and his female passenger died in a crash which split their sports car into several pieces in south-western Sydney on Monday night.
Shortly after 11pm, their Nissan Skyline clipped the front of a four-wheel drive at the intersection of Milperra Road and Marigold Street, Milperra, before hitting a power pole.
The 21-year-old driver, from Chester Hill, and his 20-year-old passenger, from Villawood, died at the scene, police said. The other passenger, a 32-year-old man, remains in a critical condition with head injuries in Liverpool Hospital.
The impact of the crash scattered debris over an extensive area. Police are appealing for the occupants of a silver car driving alongside the Skyline shortly before the crash to come forward.
Crash investigators remained at the scene until early on Tuesday morning.
Anyone with information about the crash is urged to contact the Metropolitan Crash Investigation Unit at Liverpool on 9821 8550 or Crime Stoppers on 1800 333 000
FFS! When are people going to wake up?...
It's terribly sad to see people die, that just sucks... but when people are doing stupid things on public roads it ruins it for the rest of us... i thought people where waking up and realising what stupid driving does... obviously i was wrong...
I don't understand why people have to be so stupid, especially with others in the car... for god's sake!.... I'm 20 yrs old, i own a GTR, before that i had a GTS-t (also R32) both have nice bolt on mods and i still have a clean record!....
Sorry to hear about the deaths and injuries but can we wake up please people... the police are ready to rape our ar5es as is... without this shyte to ad to it...
.. very sad news to hear
please drive safely in the holidays
and you think why the public has such a bad angle at imports & p platers?
it only takes 1 or 2
i read it was a r32 gtr, clipped a 4WD and went into a pole
apparently there was another silver car but it "fled" the scene
nah i know who they were .. they were customers of mine
and it was a r32 GTS4 and it was auto .. very sad but still silly for street racing
oh thanxs sxc180, so it was a GTS4
nonetheless, still very tragic =|
i believe r32 gts4s came in turbo, but in r33 they did not come turbo (not 100% sure though)
RIP
but as someone else said.. why?????
i have been looking forward to buying another(second) r33 for ages, and now that i am ready to buy, all of this stuff happens!!? i will still buy, but will not look forward to being public enemy number 1.
 Share
    • I thought the problem with doing this is the engine needs more timing and therefore is actually less efficient? Modern engines need very little timing to get to MBT, those super sharp edges on the squish pads are probably not the right way to get there but doing away with it entirely doesn't sound right either.
    • this explains the possibility of several maps with different boost levels
    • ok, I understand much better how we can control the boost and increase the number of psi before opening the wastegate
    • Well.... yes and perhaps no. It depends on what you mean by "spool". For most of us, the point that we would describe as where the turbo is "spooling" is the point where the wheel speed gets high enough for it to start making some boost. This is coincidentally around about the point where it starts making noise - hence the "spooling" sound. If that is what you mean, then no - the wastegate should still be shut at this point. The boost will still be way below the point where it should start opening. If, on the other hand, you mean "spool" as "reach full boost", then yes. At the point where the boost has reached target, then boost control has already started. The wastegate is already open, and has been for some time. Some short time, definitely, but still, some time. If you have no boost controller - just the wastegate actuator connected to the boost source, then you have a mechanical system working as a pressure balance. There is pressure on one side of the wastegate actuator's diaphragm from the spring, and pressure on the other side coming from the boost measurement location (the "source"). This is not a digital thing. The wastegate does not stay shut until the boost pressure reaches the spring "pressure". The spring will start to compress as soon as you start to apply any pressure onto it. This can be controlled somewhat by adding pre-load into the spring, but you cannot add enough preload to make it into a digital switch behaviour. The wastegate will crack open and start to leak exhaust out (and therefore not though the turbine) well before you reach the target boost pressure. Electronic (and some mechanical/pneumatic) boost controllers will act to prevent the boost source applying pressure to the actuator until just before you reach target boost, thus preventing the wastegate from creeping open. And some boost controllers will apply boost pressure on the spring side to further push it shut. And this can be be necessary because the exhaust pressure in the manifold also pushes on the wastegate valve and tries to open it and you cab get it leaking even without it being connected to the boost source.
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
