ok i'm tossing up between the r33 and r32, did some research on the r33's, now for the r32's, i was wondering what kinda power figures and quarter mile times a lightly modded r32 is capable of?
mods would include, pod, front mount, full exhaust, and a tune, and boosted on the standard turbo, a few ppl have been telling me that the rb20's in standard trim dont have much torque, would this kinda of set up help much with the torque issue? cause i like my cars with some torque and if the r32's dont fill my needs then i'll just spend a bit more and get the r33, will be waiting for ur advice guys, thanks
https://www.sau.com.au/forums/topic/59283-info-on-lightly-modded-r32s/
RB20's have no torque (compared with a RB25). I went with a R32 because it looks better.
Generally speaking Skylines are very robust performance cars, I guess the thing to look out for it the condition of the car (seats, carpet, steering wheel, how the gearbox feels, how dirty the motor is, how it sounds, window and door seals etc...)
yeah,i know an importer that would sell an r32 gtst w pod,hks ssqv,coilovers,r33 gtR buckets,75000ks...the one with the sunroof,also got a veilside front bar, new midnight blue paintjob and r32 gtr rims for 13,you know,for that price,youd save alot off the r33s price already,spend the difference,unless alot of bodywork done,r33s jus commodore anyway
everyone knows an importer or a friend of a friend who sells R32 for that price, but the reality is that there are costs involved in getting a car complied and on the road...
For a decent R32, you are looking at spending at least 15k.
nemz: don't mean to offend - this may be a bargain R32, but I have just seen so many similar posts - but have never seen a decent R32 for under 15.
Things to look out for: check windows, check wheel arches for rust, service history, interior condition, rubber in wheel arches (burnouts)...
Have a full mechanical insspection done including compression test!
they are 89 models though,the only problem i had was stock bov leaking boost back through plumbback,got a new one and its running fine,i really diddnt know i could get such a good example for 11,3,gave me a kakimoto exhaust 3" all the way,even had coloured drink holders lol
When i first got my R32 i did some basic mods(ehxaust, intercooler, boost and tune) which it made 190 rwkw, and ran 12.9 @117 mph on street 17" tyres. The mods didnt cost much at all ( around $1500) and left me with a close to stock 12 sec street car.
well either way dude,im not here to criticise you,nor you me,its beside the point,im sure there are alot of rip offs out there,maby the clock was wound back,but its still got original timing belt,the water pump dosent need changing,lets say it did ....whats an average for aussie conditions...18oooks a year x 15 years,thats 220,000 ks or so,what turbo engine would be running perfect after that? and if it has done over 150ooo ks im happy its running the way it is,for 11000 youd expect things to stuff up,ive had it for a year now and the only problem was that bov.
i've been looking around and its true that r32's in decent nick are really hard to find for under 15g, i've been looking at both the r32 and 33 and the r33 only seems to be a few more grand, not that much difference
on another note, about the km's issue, if its got an aftermarket speedo with the 180km plus speedo, this wouldnt be the correct km's reading right? it would be the reading from when the new speedo was put it?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
