Will i finally got off my ass and got my shit together for the ps2 modchip, so i through i give an update for another people wanting to do the same.
Basicly, i choose the option of getting a HDD (hard-drive) in my ps2 and not spending the money on a modchip itself.
So here what you need
1.HDD (there is a online which tells you the ones which will fit) I got a 120gig one
2. Buy Network adap. (so u can plug the hdd into the ps2)
3. Buy HD-Loader
Now you just plug the hdd into the network adap, then plug that into the ps2 boot up the hd-loader cd. and there u go, u can go out and rent games and just copy them straight to the hdd (got a 2gig game it took less than 15mins) or else u can hook the Hdd upto the pc and load the games on that way.
Michael
https://www.sau.com.au/forums/topic/59295-ps2-modchip-part-2/
more detail post:
MAIN POINT: YOU DONT NEED ANY FORM OF MODCHIPS!!!
Cost:
1. Hdd (must be a hdd of this list http://ps2drives.x-pec.com/ ) price range from $80 - $200
2.Ps2 Network adaptor Price $60
3. HD-Loader (doesnt matter what copy can be hdloader1/2 or advance) cost $80 (contact killer-t to buy local or else find on websites)
INSTALLION:
1. Connect HDD to network adaptor
2. Plug network adaptor into ps2
3. turn ps2 on and load HD-LOADER cd
4. 1st time running the HD-Loader it will ask you to format the hdd so that it will be in the ps2 setup
5.You now can install games buy clicking install (it is easy as putting in the game and copying it)
Option Method: You can connect the HHD to your pc (You MUST do step 4 1st) Then you must dl (or contact me for the programs) the programs that copy the games to your hdd.
Program to copy games from pc to hdd: hdl_dumb, PS2 HD Handiness
Now this program allow you to us files such as bin/cue/iso etc, so if you have dl the game you dont have to burn it to a cd to copy it to the hdd.
For games which work with the Hd-loader and ps2 hdd: http://homepage.ntlworld.com/casey.miller/...mpatibility.htm
note: mode means when you select the game in Hdloader you press select and you can pick which mode to run the game in (3types) for example WRC4 PAL, needs mode 3 select to work
+'s:
No MODCHIP
No cost for cd, dvdrs
Quicker loading time (depends on rpm speed of your HDD, loading time is next to nothing)
Programs such a divx player, media player, EMU can be install on the ps2 without an modchip
cost
-'s
Cost (depend on the cost of the HDD, it can be equal to the cost of a modchip installed)
well thats about it i think, if anyone has anymore question just pm me and i will be more than happy to help you
Thanks Michael
someone said you where using ur ps2 chip to run your car, hence no more pinging
can you confirm or deny this?
ping ping ping
i'm using an old 486 comptuer Chip to run my car you should try it TJ..........
adrian :)
Please stick to the thread...
and answer this
"sweet dude, gonna have to do this too. where did u actually buy the HDD from, online or a store?"
hey joe,
i found it hard to find a hdd and not pay an arm and a leg. I went to morely and try all shops.
In the end i would try Dicksmith or some other pc type shop, or else you could try online i cant remember any websites of the top of my head.
and yeah the new ps2 (small ones), i dont think you can do this as there is no spot for the hdd
mikey
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
