Will i finally got off my ass and got my shit together for the ps2 modchip, so i through i give an update for another people wanting to do the same.
Basicly, i choose the option of getting a HDD (hard-drive) in my ps2 and not spending the money on a modchip itself.
So here what you need
1.HDD (there is a online which tells you the ones which will fit) I got a 120gig one
2. Buy Network adap. (so u can plug the hdd into the ps2)
3. Buy HD-Loader
Now you just plug the hdd into the network adap, then plug that into the ps2 boot up the hd-loader cd. and there u go, u can go out and rent games and just copy them straight to the hdd (got a 2gig game it took less than 15mins) or else u can hook the Hdd upto the pc and load the games on that way.
Michael
https://www.sau.com.au/forums/topic/59295-ps2-modchip-part-2/
more detail post:
MAIN POINT: YOU DONT NEED ANY FORM OF MODCHIPS!!!
Cost:
1. Hdd (must be a hdd of this list http://ps2drives.x-pec.com/ ) price range from $80 - $200
2.Ps2 Network adaptor Price $60
3. HD-Loader (doesnt matter what copy can be hdloader1/2 or advance) cost $80 (contact killer-t to buy local or else find on websites)
INSTALLION:
1. Connect HDD to network adaptor
2. Plug network adaptor into ps2
3. turn ps2 on and load HD-LOADER cd
4. 1st time running the HD-Loader it will ask you to format the hdd so that it will be in the ps2 setup
5.You now can install games buy clicking install (it is easy as putting in the game and copying it)
Option Method: You can connect the HHD to your pc (You MUST do step 4 1st) Then you must dl (or contact me for the programs) the programs that copy the games to your hdd.
Program to copy games from pc to hdd: hdl_dumb, PS2 HD Handiness
Now this program allow you to us files such as bin/cue/iso etc, so if you have dl the game you dont have to burn it to a cd to copy it to the hdd.
For games which work with the Hd-loader and ps2 hdd: http://homepage.ntlworld.com/casey.miller/...mpatibility.htm
note: mode means when you select the game in Hdloader you press select and you can pick which mode to run the game in (3types) for example WRC4 PAL, needs mode 3 select to work
+'s:
No MODCHIP
No cost for cd, dvdrs
Quicker loading time (depends on rpm speed of your HDD, loading time is next to nothing)
Programs such a divx player, media player, EMU can be install on the ps2 without an modchip
cost
-'s
Cost (depend on the cost of the HDD, it can be equal to the cost of a modchip installed)
well thats about it i think, if anyone has anymore question just pm me and i will be more than happy to help you
Thanks Michael
someone said you where using ur ps2 chip to run your car, hence no more pinging
can you confirm or deny this?
ping ping ping
i'm using an old 486 comptuer Chip to run my car you should try it TJ..........
adrian :)
Please stick to the thread...
and answer this
"sweet dude, gonna have to do this too. where did u actually buy the HDD from, online or a store?"
hey joe,
i found it hard to find a hdd and not pay an arm and a leg. I went to morely and try all shops.
In the end i would try Dicksmith or some other pc type shop, or else you could try online i cant remember any websites of the top of my head.
and yeah the new ps2 (small ones), i dont think you can do this as there is no spot for the hdd
mikey
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
