Will i finally got off my ass and got my shit together for the ps2 modchip, so i through i give an update for another people wanting to do the same.
Basicly, i choose the option of getting a HDD (hard-drive) in my ps2 and not spending the money on a modchip itself.
So here what you need
1.HDD (there is a online which tells you the ones which will fit) I got a 120gig one
2. Buy Network adap. (so u can plug the hdd into the ps2)
3. Buy HD-Loader
Now you just plug the hdd into the network adap, then plug that into the ps2 boot up the hd-loader cd. and there u go, u can go out and rent games and just copy them straight to the hdd (got a 2gig game it took less than 15mins) or else u can hook the Hdd upto the pc and load the games on that way.
Michael
https://www.sau.com.au/forums/topic/59295-ps2-modchip-part-2/
more detail post:
MAIN POINT: YOU DONT NEED ANY FORM OF MODCHIPS!!!
Cost:
1. Hdd (must be a hdd of this list http://ps2drives.x-pec.com/ ) price range from $80 - $200
2.Ps2 Network adaptor Price $60
3. HD-Loader (doesnt matter what copy can be hdloader1/2 or advance) cost $80 (contact killer-t to buy local or else find on websites)
INSTALLION:
1. Connect HDD to network adaptor
2. Plug network adaptor into ps2
3. turn ps2 on and load HD-LOADER cd
4. 1st time running the HD-Loader it will ask you to format the hdd so that it will be in the ps2 setup
5.You now can install games buy clicking install (it is easy as putting in the game and copying it)
Option Method: You can connect the HHD to your pc (You MUST do step 4 1st) Then you must dl (or contact me for the programs) the programs that copy the games to your hdd.
Program to copy games from pc to hdd: hdl_dumb, PS2 HD Handiness
Now this program allow you to us files such as bin/cue/iso etc, so if you have dl the game you dont have to burn it to a cd to copy it to the hdd.
For games which work with the Hd-loader and ps2 hdd: http://homepage.ntlworld.com/casey.miller/...mpatibility.htm
note: mode means when you select the game in Hdloader you press select and you can pick which mode to run the game in (3types) for example WRC4 PAL, needs mode 3 select to work
+'s:
No MODCHIP
No cost for cd, dvdrs
Quicker loading time (depends on rpm speed of your HDD, loading time is next to nothing)
Programs such a divx player, media player, EMU can be install on the ps2 without an modchip
cost
-'s
Cost (depend on the cost of the HDD, it can be equal to the cost of a modchip installed)
well thats about it i think, if anyone has anymore question just pm me and i will be more than happy to help you
Thanks Michael
someone said you where using ur ps2 chip to run your car, hence no more pinging
can you confirm or deny this?
ping ping ping
i'm using an old 486 comptuer Chip to run my car you should try it TJ..........
adrian :)
Please stick to the thread...
and answer this
"sweet dude, gonna have to do this too. where did u actually buy the HDD from, online or a store?"
hey joe,
i found it hard to find a hdd and not pay an arm and a leg. I went to morely and try all shops.
In the end i would try Dicksmith or some other pc type shop, or else you could try online i cant remember any websites of the top of my head.
and yeah the new ps2 (small ones), i dont think you can do this as there is no spot for the hdd
mikey
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
