ok
we have all heard or done the Nasho run, the old pac run or just been on a cruise to bondi, the gong and even the harbour bridge
i was just wondering if anyone has some roads which they enjoy driving along, due to:
a. the twists / turns
b. the crowd nearby
c. the other cars you see in the area
i was just thinking this because the other weekend i did the cattai ridge road up near windsor / wisemans ferry and found it a very nice ride. it isnt long and has straights twists and not much traffic in a country area.
i started on windsor road and ended up at wisemans ferry.
any other fav drives out there?
https://www.sau.com.au/forums/topic/5931-cruise-routes-where-you-go/
I drive on them because of the twisty bits and also cos theres hardly any traffic so its relatively safe to have a squirt now and then.
Nasho rocks, so does OPH, Old Northern Road is not bad and Putty Road is good.
need to try Kanagaroo Valley and Macqaurie pass, and one day Great Ocean Drive!
anyone tried the galston gorge? LOL, awesome road, just that eveyrtime I've been theres been fags coming the other way who cant keep to their lane
I would like to drive to JAPAN.
I heard its a good run. No coppers
I've done this and clocked 250km/hr in one of the tunnels between Tokyo and Yokohama with 4 ppl in the car. I've never been pulled over speeding once there hehe
of course radar detectors are legal there too ;)
Best drive I ever had.
Left Nowra early one morning, came back to Sydney via Kangaroo Valley. 1st was the hillclimb out of Nowra. Turbo's love hills!! Hairpin after hairpin until you get to the top and then it's the decent, this is where you appreciate the superior brakes your car has, scenic Kangaroo Valley to get some culture as you crawl along at 50, then back into it again and come back via rear of Bowral on country roads. Finally the freeway to Sydney if your game to risk it.
Big drive but that's what I like!!!
You for real? Lucky bastard. Dam I envy you. I would love to fang it on the highways of tokyo!
Hey, I went on an Audi drive day back in Feb this year with my old man, when they released the updated (current) version of the A6 range (including the 4.2 V8 S6 and 2.7 V6TT in sedan and Allroad forms).
If I remember correctly, it lead from The Audi Centre in Parra, along Windsor Rd thru to Wilberforce, along Putty Rd, into the Hunter Valley, stopping at Pokolbin for lunch, then more driving through the Hunter on the way back to meeting up with the F3 for the return trip home.
First car was the Allroad 2.7 Twin Turbo - touchy throttle off the line, but VERY responsive and nice to drive once you're on the move.
The highlight of the day (obviously - and for EVERYONE else who'd had the chance to drive it before we discussed it at lunch) was driving the S6. Lush 4.2l V8, quad cams, 5-valves per cylinder, 250kW/420Nm, quattro drivetrain, 5-speed Tiptronic auto, leather Recaros, etc.
0-100km.h in 6.7secs, not bad at all for something that weights 1735kgs, hey? God only knows what the RS6 is gonna be like - basically the same engine but TWIN TURBOCHARGED.
According to my old man, I was heading into a 35km/h sign-posted corner at around 100 - haven't driven like that with him before or since, and probably never will... My dad just cruised, unfortunately - it's been a while since I've seen him drive "in anger."
One of the guys along for the drive apparently hit 235 in the S6 before he backed off - and he was in his late 40's or early 50's. The same guy drives an old S4 every day (from the early 90's, based on the old Audi 100 shell - 5cyl, 20v, 2.2litre turbo, 6sp manual, quattro).
Anyway, back to the main point of this thread, that was a great drive - gotta find the map we used and do it again soon.
I've also enjoyed the run along Ku-Ring-Gai Chase Rd, heading into Bobbin Head, and the drive out back to the Pacific Highway is alright too. I've been pretty close to the point between slip and grip thru there, and according to my sister I've also gotten pretty close to scrubbing the barriers along the passenger side of the car on the drive (thrash?) down.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
