Difference Between R34 GTR - GTT
what are the differences between these because i just thought that the gtt was the 4 door version of gtr but then i saw a 2dr gtt the other day. can somone give me specs or explain this.
like i was looking at this 4door gtt
http://www.prestigemotorsport.com.au/au/st...sp?StockID=2817
like why is it so cheap? are they just cheaper in general compared to gtr? less power? etc
thanks in advance
Big differences
GTT is the GTR's little brother... different engine, twin turbo = GTR, single turbo for GTT, less power than GTR, GTR is 4wd, GTT is rwd, interior is all different - bucket seats for GTR, bigger wheels for GTR... flaired guards on GTR, different body kit,
way to much different to mention...
GTT = Gtst if you know what they are
GTTs are RWD coupes and sedans with hicas and have the Neo rb25det making 206kw (280hp)
the GTRs have the RB26DETT (206kw, around 395nm), they were only made as coupes. They come with the attesa awd system and hicas. different interior.
Theres a big difference in price between them aswell - gtrs go for +$75000
Theyre cheaper because they dont have the features that the GTR has, plus that sedan is an auto which drives prices down and its a sedan. The gtr is a fair bit quicker than the gtts aswell.
damn it, GTR is like 260kw's - dmx, don't worry about any power figures u read on the net for GTR's, ain't right. More around 260kw's.
So NO, not the same power.
GT-T = 206kw's
GTR = 260kw's (approx)
you looking at buying the 4 door?
EDIT: front lights are the same for GTR and GT-T
R34 GTR
RB26DETT 206kW
4WD
Coupe
Different Body Kit
18" Rims
Inside Computer
R34 GT-t
RB25DET 206kW
Different Body, Front Lights are a tab different
Coupe and Sedan
RW Drive
That’s the major differences.
R34 GT-R rims are 19inch not 18
  • 12 years later...
Old thread but can anybody confirm if the arm rest console length are the same for r34 gtr and gtt. Just wondering if you can swap the gtr boots console into the gtt ..will it fit?? Or needs the arm rest console changed to a gtr one..
 Share
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
