just got back from overseas
car was sitting in the yard for 5 weeks, and dad didnt start her up at all. tried to start her up but the battery was flat, which i had dad hook up his battery, still no worky
car won't kick over, cant push start cos its in the back yard.
any ideas anyone, i was really looking forward to going for a drive, but cant :rofl:
help ;)
https://www.sau.com.au/forums/topic/59343-car-help/
Umm guys - original post says Dads battery used (assume good), still no worky.
Does it Krank at all, or is it a click, or nothing.
Also assuming member of NRMA or willing/able to pay call out fee.
All obvious checked (fuel, fuses, rotor button/lead, plugs, etc..). Didnt disable to prevent theft whilst OS. Doesn't smell fuelly like flooded ? Is it a carboureted car? Fuel pump/filter ok?
Sounds like no spark but for what reason. If already tested with good battery hows starter motor, coil? etc...
Process of elimination start at the obvious and least expensive and work through it. Have fuel?, spark? and lastly oxygen
Just a thought so dont flame me.
https://www.sau.com.au/forums/topic/59343-car-help/#findComment-1132579
10 points for scooby!
should have made it clear that i only hooked up dads battery to mine by jumper leads.
put dads battery in an hour ago and she started up beautifully, then transferred my dead one over, and i've left the car running for the last hour. will shower and drive out to the battery shop, see what they think - yes sir, it's dead, well not completely, but it's christmas, and i need money, so buy this new lovely battery.
thanks for all the help everyone!
oh, and i drove the car a mere 15m from the yard into the driveway, it was like driving a car for the first time, having gone so long without. should take it slowly today :)
https://www.sau.com.au/forums/topic/59343-car-help/#findComment-1133494
On another note, you really shouldn't jump start a car with an ecu installed. You can if you have an antistatic lead and/or a zap box. As Rachel Hunter says...................iwhobiwh.
Just be aware that you can send a zap to the ecu and scramble its poor little brain.
Better/safer to swap batteries.
https://www.sau.com.au/forums/topic/59343-car-help/#findComment-1133906
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
