Can anyone tell me if the speed sensor on an r32 is dependent on the speedo drive?
Problem is like this, I got in my car this arvo, left work and noticed the speedo wasn't working. I was pissed. Then the car decides to stall everytime i pull up, which it does occasionally when it's hot started so i wasn't that worried. Then i noticed the steering was really bloody light, and then the Hicas light came on.
Now about the only thing i could think of for the 2 going at the same time (other than me being unlucky) is that the speedo drive is used for the HICAS speed input somehow off the back of the dash.
Hicas is already locked.
Already checked all the plugs on the hicas are in and the fluid is full. Checked the speedo drive is plugged in at the gearbox end and that it still turns freely, haven't pulled the dash out yet to see if it's come off there. And will probably pull the speedo drive unit out of the box over the holidays to see if the teeth have stripped off it.
Any other suggestions?
Cheers
Dave
https://www.sau.com.au/forums/topic/59346-speedo-and-hicas-stuffed/
Speedo cable is falling apart from the look of it at the dash end, jammed it back together temporarily and it has fixed the speedo for now, will now see if it fixes the hicas issues when i go out in the morning.
Same thing happened to me, Yes. Hicas is dependant on a speed sensor which is plugged into the back of your speedo. My Turbo timer wiring was not making a solid connection with my dash so this threw my HICAS out of wack too.
So in other words, No speed sensor = No Hicas.. but your speedo may work perfectly it all has to do with the wiring in the back. You should run a HICAS diagnostics to be sure.
Yeah, the hicas seems to have been sorted out with the speedo cable bodgy fix.
Which makes me wonder how screwed up is the hicas/power steering for all the guys who cut the speed sensor wire to the ecu.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
