I guess this soughta stuff is posted all the time, i did a search on the forums and couldnt find the desired info.
Im looking at upgrading to a FMIC and a GTR inlet manifold for my R32. Im finding very hard to get my hands on a GTR inlet manifold/plenum. ANyone got any suggestions and.or a rough price on the manifold/plenum?
Cheers!
https://www.sau.com.au/forums/topic/59363-mods/
Zoom, irrespective what you think of them, did tests on RB20 with the stock Vs. GTR inlet manifold and plenum, and the GTR item performed far WOSRE than the stocker.
When you've only got 2ltrs of swept volume having good tuned length inlet runners, to boost low down torque, is kinda important!
If you're trying to make piping simpler for your FMIC you're going to need to get a custom inlet made by someone who REALLY knows what they're doing! $$$
Just stick with front cross over pipe or bending under the intercooler option, i prefer the former, but the later is simpler to install and looks more stock.
https://www.sau.com.au/forums/topic/59363-mods/#findComment-1133464
Cheers guys much appreciated! I was under the impression that the GTR Inlet would make the cooler piping easier and reduce lag. But i love my torque and im not to keen on throwing a few grand in just for a custom plenum. If i was gonna make the car a total animal i would consider it, but thats the not the case.
My next and final question: Would this FMIC Kit be worth the cash?
http://www.horsepowerinabox.com/HPIAB2/category8_1.htm
Thanks!
https://www.sau.com.au/forums/topic/59363-mods/#findComment-1134237
I just got that exact kit, but for $995 as part of a christmas special on NissanSilvia forums, seems pretty good quality but be prepared to cut a hole in the side below your battery and butcher your stock bar to get it all to fit.
Mine was missing the promised templates but you can work it all out easy enough.
https://www.sau.com.au/forums/topic/59363-mods/#findComment-1135033
so if you are changing your plenum, why would you buy an intercooler kit which supports you current setup. you mayswell buy a cooler and have the plumbing done separately as they will not match up!
dont know i suppose if you are not getting the plenum for while it would ok and you could modify plumbing later?
dunno!
https://www.sau.com.au/forums/topic/59363-mods/#findComment-1140091
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
