I have the R32 GTR Manual, R32 GTST manual and the R33 GTR+GTST Manual.
These include all engines of the following:
CA18i
RB20E
RB20DE
RB20DET
RB25DE
RB26DETT (R32)
RB25DE (R33)
RB25DET (R33)
RB26DETT (R33)
Includes all info for 4wd systems and electrical and chassis information. They are all in English and I will be setting up a FTP server to host them.
Please let me know if you are interested and what connection your internet is so I have a fair idea how far to break it down.
I will be willing to post them but at your own expense. I have them all included in a drop down autorun menu ready to go.
https://www.sau.com.au/forums/topic/59368-r32r33-gtrgtst-manuals-in-english/
also, if that one is not working. I will be starting a different server at 6pm tomorrow 23/12/04. If anyone is still downloading from the original at that time, you will be kicked.
You can log on to ftp://[email protected]:77
Sorry, edited that one back. I did the transition just now.
Just use this one, it should be faster as I have direct cable and this server will utilize it. Should be faster for those of you with adsl and cable.
I've placed a mirror on my server... but if it gets raped, I'll remove it..
i'm only 60kps upstream.. so be good!
http://skeleton.net.nz/~oiad/manual/R32 - GTR Manual.rar (20.8MB)
http://skeleton.net.nz/~oiad/manual/R32 - GTST Manual.rar (22.5MB)
http://skeleton.net.nz/~oiad/manual/R33 - GTST+GTR Manual.pdf://http://skeleton.net.nz/~oiad/manual...+GTR Manual.pdf (149 MB)
You may want to use a download resumer or something.. the server is pretty stable, but I see a few people starting, then stopping..
THE NEW SERVERS ARE AS FOLLOWS. (MY IP CHANGES WHEN I REBOOT)
IP: 60.226.67.88 USERNAME: SKYLINE PORTS: 21,77 OR 99
well i managed to get ftp://60.226.67.88:77 but it prompts for a username i have put in
Username: SKYLINE password: blank
Username: SKYLINE password: SKYLINE
Username: skyline password: blank
Username skyline password: skyline
also log on anonymously
no goer ???
salival Thanks for the link. I successfully downloaded the file but can't open it. I don't know much about computers. It says windows needs to know the program that created it. What should I type in?
download winrar and install that. www.win-rar.com
once you have extracted the PDF, you'll also need Adobe Acrobat Viewer. www.adobe.com both are a free download
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
