Well, it's all down to where me and the future missus want to live. It's a toss between here and the US.
If it's here I will get a stripped R32 gtst for trackday hooning.
If it's in the US, it's gonna ba a yank tank. Corvette or Viper.
I hope it's not there cause there ain't many race tracks which aren't oval. Though Laguna Seca would be something to have a go at.
https://www.sau.com.au/forums/topic/59377-its-gooooone/#findComment-1134461
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
