hey guy,
i got this off ns.com and thought i'd share it, 2days later im still giggling at it.
Rectum stretcher
While I was driving down the Kwinana Freeway the
other day, (going a little faster than I should have
been) I passed under a bridge only to see a traffic
cop on the other side with a radar gun laying in
wait.
The cop pulled me over, walked up to the car, and
with that classic patronising smirk, asked: "Runway
too short?"
To which I replied,
"I'm late for work."
To which he asked, "What do you do?"
"I'm a rectum stretcher," I responded.
The traffic cop was surprised and confused. "A
what? A rectum stretcher?? And just what does
a rectum stretcher do?"
"Well," I said, "I start by inserting one finger, then I
work my way up to two fingers, then three, then four,
then with my whole hand in, work side to side until
I can get both hands in, and then I slowly but surely
stretch the hole, until it's about 6 feet."
Then the cop asked questioningly and cautiously,
"And just what do you do with a six-foot arsehole?"
To which I politely replied, "You give him a radar
gun and park him behind a bridge..."
Speeding ticket: $250
Court costs: $1000
Look on traffic cop's face: Priceless!!
https://www.sau.com.au/forums/topic/59395-rectum-stretcher/
May as well add to the Christmas cheer.
Three men died on Christmas Eve and were met by Saint Peter at the pearly gates.
"In honor of this holy season," Saint Peter said, "you must each possess something that symbolizes Christmas to get into heaven."
The first man fumbled through his pockets and pulled out a lighter. He flicked it on.
"It represents a candle," he said.
"You may pass through the pearly gates," Saint Peter said.
The second man reached into his pocket and pulled out a set of keys.
He shook them and said, "They're bells."
Saint Peter said, "you may pass through the pearly gates."
The third man started searching desperately through his pockets and finally pulled out a pair of women's panties.
St. Peter looked at the man with a raised eyebrow and asked, "And just what do those symbolize?"
The man replied, "They're Carol's."
https://www.sau.com.au/forums/topic/59395-rectum-stretcher/#findComment-1133431
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
