To minimize the spillage when removing the cooler... find two bolts to plug up the hoses with :D
Works a charm...
Remember, DO NOT EMPTY THE OIL INTO THE DRAIN! How would you like it if someone poured oil in your water bottle :P
So, how do you fill the oil up again? I take it there is a dipstick to check the level?
If you pull the top hose off and run the motor to empty the trans, wouldn't the cooler itself still be full of oil (and it would subsequently go everywhere)?
Sorry for all the questions.
Andrew
You fill the tranny through the dipstick tube.
I just pissed oil overwhere. Removed the hoe here and there and tried to get all i could. First i drained the sump though.
Also, i didnt jack my car up as i didnt want it on an angle to drain the oil.
I got a funnel and some hose, put them together, and stuck the hose in the dipstick tube. That is my dodgy assed method.
Alex, I've never totaly drained an auto with out taking converter out. Were u able 2 do that or r u only draining out what is pan and cooler lines. 2lt. doesn't sound much 4 an auto box. I want drain completely if poss. to fill with fresh fluid. I recon the auto would love that and may also sharpen changes a bit!. Cheers.
I removed the pan, you get about 1 to 2 litres, replace this with the same amount as you get out, also clean the filter while the pan is off, mine was filthy. Then take the line off the cooler thats coming from the box, start the car and pump out and measure 1 litre of oil, turn the car off, then replace it, keep repeating this until the oil looks clean.
Took about 8 litres for the oil to become clean.
From what i understand they hold around 12 litres all up.
just a quick one to all those after trans coolers i have just had some PWR >_< coolers come into Supercheap Auto that are priced at the same as our generic one $85 :D:yes: for one that is rated for a V8. If you are after one and have trouble getting hold of one PM me and i will get one for you
cheers
  • 2 years later...
that's clever... cheers for that
How about a variation... take the cooler inlet hose off, dunk it in a bucket marked 'old transmission fluid', and put this down low, say on the ground. Then, attach a length of temporary hose to the inlet of the cooler, and hold this in your new oil container.
...or, to make things easier on the trans oil pump, you could arrange a gravity-fed setup of a clear plastic bottle inverted, with the hose in the lid. That way you can even meter the level going in... I've never tried this but thought it could work?
Edited by DaveB
Hey guys it seems that nobody has asked yet, but is the trans cooler upgrade as relevent to series 2's? They appear to have a much more substantial cooler than the S1's simple "finned loop" - looks like a 'proper' radiator (same style as radiator), don't know my tube & fin from my plate & bar tho. Just wondered if the tiptronic needs something bigger than that?
Edited by DaveB
  • 4 weeks later...
I have finally fitted the large (Davies Craig) auto transmission cooler to the Stagea. The part number I chose was 678 which is the largest universal (280 X 216 X 19) I could find with 3/8" fittings. The catalogue specifies for engines "4.2 litres and over"
I will post up some pictures of the installation tomorrow. :D
For Kiwi readers this unit is available (by mail order if necessary) from Silverdale radiators for $149 +postage (saw it on Trade Me).
  • 1 month later...
Go into Supercheap and see if the 678 is bigger than yours. If not I read in a US car magazine a suggestion to go to the scrap merchant and get a huge heat exchanger out of an aircond unit basically for the price of the scrap value. Then you have to make up your own mounts and buy some hoses.
  • 8 months later...
Fitted a PWR cooler last friday. Was a rather easy task. I used the same bracket and just drilled an extra hole in the cooler and bracket the same as SK did.
Felt the cooler today after driving to work-30 min freeway drive and it was warm to touch but not hot at all.
Also looks mean from the front cos intercooler is down low then in the grill on the left you can just see the trans cooler :)
i still dont have one, my trans is waiting on gasket and filter before i can service it(getting genuine nissan brought in) i have a shit kit, and my fluid is as new, over 12months and 30k km on!
  • 4 weeks later...
Hi all,
Just thought I'd share that I visited MV auto's in Adelaide about my standard (as far as I know) trans cooler on my S2. It is pretty large, a lot more substantial than the S1's and possibly even larger than the Davies Craig jobbie in those pictures that SK fitted. MV's advice was that it was a good size and didn't require upgrading; only that it would need relocating if I was to fit an intercooler. Which I will do eventually... and a high-stall convertor is sounding more like a good idea as my GCG hi-flow turbo is lacking in stall-launches compared to the stock turbo.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
