Which Sard regulator do I need for a R33 GTS-T?
Generic adjustable fuel regulator. 8mm nipple type. 50mm diameter x 96mm.
or
Generic adjustable fuel regulator. AN#6 type. 50mm diameter x 96mm
Please let me know if anyone knows,
as I need to order one today???:wassup: :wassup: :wassup: :wassup: :wassup:
https://www.sau.com.au/forums/topic/59410-which-sard-regulator-to-get/
so which one should I get????
#69010   8mm nipple type
or
#69011  AN#6 type
Get the 8mm nipple type. That way you can use standard hose and clamps
You will also need the adaptor onto the fuel rail
Can not remember the Sard part number, but all the nissans are the same
http://hioctaneracing.com.au/eshop/product...products_id=168
I have one of these on my r33
I mounted the regulator on the rh strut tower and piped it up from there
Also get yourself a 40mm gauge about $15-20 so you can tell what fuel pressure you are running
These screw straight into the side of the regulator.
Hope this helps
Will a fuel regulator make the car run richer?
Also how many km's will you lose out of a tank of fuel?
A fuel regulator is exactly that
The fuel pump pumps at a higher pressure than the injectors need
So the fuel regulator controls the fuel pressure to the injectors
Your factory engine has one already fitted
By replacing with a adjustable rising rate aftermarket one. it allows you run a higher pressure then the standard one, hence forcing more fuel thru the injectors
You only need to fit one if you need more fuel i.e if running higher boost or other upgrades
So yes you will use more fuel
how much who knows, all depends how you drive.
Thanks for that :)
I have a GTR pump which is fine, although i would like to run a bit richer on 1bar.
Will more fuel increase power?
Thanks for that :)
Only if you need it
Best get your car dyno then you will know for sure it it is too lean
