254 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Gotta say I am a 32 fan all day way GTS-T or GTR so yup 32 is def my fave, next to that would be the 34 then 33.. I really hate choosing but seriously NO SKYLINE IS UGLY!!!! I cant believe you'd even think it :) every skyline has potential (fave 33 for instance krzysiu :))
  • Replies 75
ohh i have a bit of a retro (or 'old school') fetish. dr30/r31 passage. mm. for that matter, i like pretty much all dark, low 4-doors. (dr30 aside, as it looks best in its original two tone paint and rs-x turbo printed on the rear doors :drool:)
out of the three being poled? r34, cause there rarer and no one can afford them :)
  • 4 weeks later...
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
