As title suggest this KIT consist of TURBO, MANIFOLD, WASTEGATE
came off a RB20 GTS4.... hence the manifold has been modified in japan to clear 4wd sump.....kit has not been used in australia yet....from what i have noticed there is no shaftplay whatsoever
kit however will still fit normal rb20/25 and if youve got a gts4 ur also in luck
pics are here
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...item=4514002128
.... this kit has proven itself on rb's to produce a comfortable 250rwkw
price $2600
regards steve :headspin: :headspin: :headspin:
https://www.sau.com.au/forums/topic/59432-trustgreddy-td06-20g-turbo-kit/
What sized A/R exhaust housing? If its an 8cm would you be interested in swapping for a 10cm. Make the kit much more suitable for an RB25, and on a std RB20 makes 16psi at about 4700rpm.
My 10cm housing has been ceramic coated also
