Hi ppls,
Now the motor is well and truly run in I am going to go for the Motul 8100 X-CESS 5W-40. Its a decent synthetic oil that is PAO, i.e not a half arsed synthetic.
The next step up from PAO is the ester based oils which are big $$.
Close to $100 for around 5ltrs.
The Motul 8100 X-CESS 5W-40 is $59.95 for 5ltrs which is fairly decent.
It should be interesting how the 5w-40 goes, there is a bloke at Autobarn that runs it in his RB26DETT. Its fine and holds oil pressure in heavy traffic (unlike mobil 1).
Let me know of any experiences with this oil.
https://www.sau.com.au/forums/topic/59476-my-oil-choice/
I'm not going to play around mixing oils.
$40 adds up over a 5,000km change interval.
I'll see how it goes, if the oil analysis comes back nice I'll stick with the oil and possible extend the drain intervals.
I've seen a few analysis reports with the Motul gear and it is a pretty damn good oil.
If the report contains a little too much bearing wear I'll jump up to the 300v.
I do quite a lot of kays ~30,000km's per year.
It all adds up. Especially Studying full time at Uni and trying to support my continual list of mods habbit. :)
https://www.sau.com.au/forums/topic/59476-my-oil-choice/#findComment-1134857
Ive run Motul 8100 for the last 3 or more changes.
Found the response a little better than Mobil 1, but i have no idea about wear on bearings etc.
I'm thinking of changing to Castrol Formula R (a lot thicker tho) to see how it goes.
https://www.sau.com.au/forums/topic/59476-my-oil-choice/#findComment-1135213
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
