  • Replies 416
Posted Images
i'm a lvl 44 ne rogue on blackrock, with a 15 druid on the same server. also have a lvl 20 tuaren shaman on Kargath.
rogue is very kewl, u might be abit crapped off at the rogue from the mid teens till when u get ur poisons after that your dps skyrockets :)
i went herb/alch on the rogue as it suit you very well the heals and buff potions are a saviour as is 'vanish' once you get it.
yeah i might stop using paladin and go to ne rogue again for blackrock, i wuold get to 12 quicker than what i did originally because i'd know where to go
plus they look the shit!
although paladine armor choise is sweet
well i borrowed my mates copy and installed it last nite. it sez i have around constant 600ms latency, BUT IT DOES NOT LAG ONE BIT! i swear i couldnt belive wot i was seeing!
thanks anyways!
wot server and stuff you guys on? =] maybe ill see yas in there (wen i get it!)
hurry get broadband! you dont want to miss out!
ive got DSL now... but im moving out soon-ish and wont have a PC for a few months.
worthles paying for WoW now just for a month or two then not playing for ages.
i couldnt handle it
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
