Hey guys i currently have the stock speakers in my r33 series 1.5 and im just wondering what size speakers will fit straight in without any (or very little) modification. Would 6" + tweeters for the front and 6.5" 2 way coax's be ok for the back, or just 6"
https://www.sau.com.au/forums/topic/59517-what-size-speakers/
Its 6" on all four corners in the R33....
(6" or 6.5" is the same thing)
You can go quite deep with no modification in the doors. (I have Infinity Kappa components in my doors with no modification) All you would need to do to modify it is cut the back of the factory pod off, easy as hell.
In the rear, you will need to modify the factory hole if fitting a chunky 6", the factory holes arent a perfect circle. Just get a hammer out and tap it into shape
Got Alpine SPR-174A 2 Way 6.5" Coaxials in my SII Sedan, fit perfectly with no mods except to remove the child restrainsts, as they wouldnt sit over the speaker because of the tweeters. I was told that fronts would take an Alpine R series 6" split, not sure how reliable that info is though.
Got Alpine SPR-174A 2 Way 6.5" Coaxials for rears in my SII R33 Sedan, fit perfectly with no mods except to remove the child restrainsts, as they wouldnt sit over the speaker because of the tweeters. I was told that fronts would take an Alpine R series 6" split, not sure how reliable that info is though.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
