are there gonna be more of these twilight sprints throughout the year?
I have learnt from all of your misfortunes and the Stealth S15 is gonna be indestructable when it hits the track again
Will have to wait and see... I'd say it's likely there will be further twilight events this year.
Oh, and nothing is indestructable :)
  • Replies 314
What class are we entering in? I assume they (WRX Club Organisers) will just put us in an SAU class? Like the HSV club did when we joined their track day at Phillip Island.
Any1 know? Snowman?
Any1 know?  Snowman?
All non-WRX club members will be in the Associate Class. There are 70 spots available in total across all classes, first come first serve.
:P
Gawd, so much to do before then. I HAVE to get my car retuned, I've had it on the dyno 3 times at Ice and still no job, pings off it's nut in 3rd and 4th round 5000rpm under load. The support systems are all A-Ok so it has to be the maps. I've gotta take it down to Racepace some time soon.
Also gotta get some semi's and wouldn't have a clue what rims they will go on....
uuuugh.....
Ill pay up front, but i fear i will be struggling to make it considering im spending 2 wks in SA this month:(
Yeh looking at the ignition map on my car i want to get it re-tuned as well, its very conservative, which sure is safe, but id rather a more moderate tune to get the same power at less boost. If the car fires up first go this weekend im a good chance:)
Can someone fill me out a form???? I'm back next week.
We would be in associate class. Don't worry about that side of things too much.
I'll see what I can do, I have most of your details here. Thing is it wont be sent till monday. When will you be back?
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
