Andrew - Can u please ask ur 'tuner' from WA if he could possibly tune my car aswell while its at Ben's???? Willing to pay big dollar!!!! Oh sh!t, haven't got Tomei cams so looks like I'll have to wait for that extra 90 rwkws.....
By the way, i think you should change ur username to WOLFMAN!!!!
  • Replies 314
Yeah Jack without the cams, and without spending hours checking every possible timing combination then your really not committed to the cause.
But anyways.... the rain has stopped and I seem to be feeling a lot better today. Lets see if I can't make the shit stop.
I saw your engine yesterday Jack - was looking good. But still had a long way to go. I should get my car back today which I can't wait for. Was speaking to Benno and it seem's you should have about 20rwkw's more than me so it will be fun to see exactly how much difference that makes. On the track the extra lag you have shouldn't be an issue I don't think?
Andrew - you'd be surprised at the amount of lag you'll have now aswell!!! Both turbos are pretty much on par with each other in regards to lag, around 5k rpm full boost.... Cams should bring full boost on a little earlier.....
Well I started a thread last year about it but the answer is still inconclusive as yet. But basically the 32/33 gearbox has a 1:1 ratio in 4th. But the 34 box has its 1:1 in 5th. So I have an "extra" gear in there to play with. So it should be much easier to select a gear in a useable power range thus reducing the effects of lag.
But having said that I havent driven the car with 2nd gear in over 6 months so I may forget I've even got it come tomorrow night! LOL. And Im guessing the 2 hairpins will be 2nd gear corners. But initially I will be trying them in 3rd anyways as my main objective tomorrow night is to come home with a fully functioning car - including gearbox, engine and panels. So if it means a bit of extra lag then so be it. Im not yet ready to test my direct 5th-2nd gear changing skills. I can't afford to break the damn thing again.
Bad news team. I'm unable to tune out the high knock that has developed. I'm pretty sure a dirty load of fuel was the culprit and the fuel system needs attention so clean and new filter plus clean the injectors, so while I should be good to swing by and offer support, i have now withdrawn my entry. I'm not going to compromise a good engine for the sake of a single event.
The O2 sensor gave me an extra 300 rpm at idle for some reason but still have the knock up around 100-140
Now to get the goodies together and get a tune with the lot. Reground GTR cams, 440CC injectors and the Z32 AFM.
Anyone got an early GTR/R33GTSt hand controller they can lend me so I can have more of a play? Time to sort my laptop and get FC datalogit.
My house mate is having a party at my place but its probably to far out of the way for most of you. I'm in parkdale. Also ferni you can borrow the digi display if I can get it in time. If somebody has a laptop we could data log if somebody can get the program to work. Had it working the other day with a mates one on the home computer and a cable through the window.
I have a laptop and am bringing it to access the laptimes over wireless, your welcome to use it to log some data as well if you like
do you have the serial cable? what serial cable do you need? female to female 9pin?
Anyone from the S.E Suburbs want to meet up to cruise to this together this arvo? (mainly because i suck with directions and will probably get lost :) )
its easy. Just get on the Calder Fwy and start driving until you see the Thunderdome. :)
I think it was a good day out, .....well this is coming from someone who didn't participate but we still enjoyed ourselves, especially watching Troy who got sideways on the 3rd and second to last corners a few times, Andrew with his 34 for obvious reasons, ferni who spun once or twice, and that guy in grey 32 with the RB26 who looked at one stage like he was going to run into the back of Rianto whilst braking for the 3rd to last corner- front left locked up it looked like :D....
I got heaps of photos but can't really be fu(ked putting them all up.... if any of you guys want a few just give me your email addy....
.....There not the best quality...........................
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
