First started off running late for work. Then I took off down ennis ave, got to about 90-100 and i heard a loud tick tick tick, pulled over and it seems that my right front tyre had delaminated (which had been pretty bad for a while I admit).
SO, i goto get a price for a new tyre, and one of the workers there reversed into my car while it was parked in their car park. About $1400 worth of damage apparently, also turns out that all the local panelbeaters have already finished for xmas and they wont be back until Jan 4 (one not back for 4 weeks!?!)
Turning out to be a good xmas so far
https://www.sau.com.au/forums/topic/59521-another-bad-day/
well i was supposed to get my car last week, but it got delayed, so i was supposed to get my car this week, they wernt sure when, maybe monday maybe wednesday.
so i stayed home all week wating like a stupid d!ck, then canbera called and said i had a problem with the paper work, so i had to re fax a letter, which delayed it more,
and the car had to steam cleaned but the cleaners finished today early (firday) and now its gonna sit in there lot till tuesday where itll probley get broken into or some shit.
i also have to go to busselton this arvo, then drive back on tuesday to get the car, then drive back to busselton.
its gonna be a shit holiday......
steve
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135466
damono.... bad luck bro... pitty it wasnt the front bar they reversed into... considering u were after a new one anyways...
oh well... could do a front and rear bar now... (im assuming they hit ure rear end?)
my day was pretty average
clutch still going gay as hell... cant drive my car the way i want... have to drive like some half assed panzy (which in one way is good... least i wont get pulled up for racing or anything whilst its DD) but yeah... boss at work had another whinge at me today... cus he is a moody tard when he wants to be...
and yeah..
i feel for u guys...
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135564
Shit. And I thought my $550 worth of damage was bad :D
Sorry to hear about the little mishap with your car man. I'm in the same boat as you. Cant get my car to a panel beater until Jan 11!!!!! Pheck!
As for everyone else, I'm sure the X-mas holidays will all cheer you up :)
Merry Xmas everyone!! :D :burnout:
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135588
the mofo who was 'fixing my car' put a friggin ciggerette lighter burn (im talking like massive and almost purposely) in my otherwise perfect back seats. wtf was h e doin in the backseat, and why the hell are there lollie wrappers on the back floor?
then some mofo ran a trolly up one of me panels, leaving a nice litle xmas racing line infront of the rear 1/4 panel.
thank you garden city patrons!
and i was always paranoid at carosmell.
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1137431
I had the exact same thing happen to my RX7, the guy told me that he took it for a test drive around the block and dropped his smoke out the window ( WHY THE CRAP WAS HE SMOKING IN MY CAR ???) I found the smoke on the back seat with a burn mark about 3cm wide, If it was the front seats he would have died.. $350 each.
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1140214
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
