First started off running late for work. Then I took off down ennis ave, got to about 90-100 and i heard a loud tick tick tick, pulled over and it seems that my right front tyre had delaminated (which had been pretty bad for a while I admit).
SO, i goto get a price for a new tyre, and one of the workers there reversed into my car while it was parked in their car park. About $1400 worth of damage apparently, also turns out that all the local panelbeaters have already finished for xmas and they wont be back until Jan 4 (one not back for 4 weeks!?!)
Turning out to be a good xmas so far
https://www.sau.com.au/forums/topic/59521-another-bad-day/
well i was supposed to get my car last week, but it got delayed, so i was supposed to get my car this week, they wernt sure when, maybe monday maybe wednesday.
so i stayed home all week wating like a stupid d!ck, then canbera called and said i had a problem with the paper work, so i had to re fax a letter, which delayed it more,
and the car had to steam cleaned but the cleaners finished today early (firday) and now its gonna sit in there lot till tuesday where itll probley get broken into or some shit.
i also have to go to busselton this arvo, then drive back on tuesday to get the car, then drive back to busselton.
its gonna be a shit holiday......
steve
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135466
damono.... bad luck bro... pitty it wasnt the front bar they reversed into... considering u were after a new one anyways...
oh well... could do a front and rear bar now... (im assuming they hit ure rear end?)
my day was pretty average
clutch still going gay as hell... cant drive my car the way i want... have to drive like some half assed panzy (which in one way is good... least i wont get pulled up for racing or anything whilst its DD) but yeah... boss at work had another whinge at me today... cus he is a moody tard when he wants to be...
and yeah..
i feel for u guys...
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135564
Shit. And I thought my $550 worth of damage was bad :D
Sorry to hear about the little mishap with your car man. I'm in the same boat as you. Cant get my car to a panel beater until Jan 11!!!!! Pheck!
As for everyone else, I'm sure the X-mas holidays will all cheer you up :)
Merry Xmas everyone!! :D :burnout:
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1135588
the mofo who was 'fixing my car' put a friggin ciggerette lighter burn (im talking like massive and almost purposely) in my otherwise perfect back seats. wtf was h e doin in the backseat, and why the hell are there lollie wrappers on the back floor?
then some mofo ran a trolly up one of me panels, leaving a nice litle xmas racing line infront of the rear 1/4 panel.
thank you garden city patrons!
and i was always paranoid at carosmell.
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1137431
I had the exact same thing happen to my RX7, the guy told me that he took it for a test drive around the block and dropped his smoke out the window ( WHY THE CRAP WAS HE SMOKING IN MY CAR ???) I found the smoke on the back seat with a burn mark about 3cm wide, If it was the front seats he would have died.. $350 each.
https://www.sau.com.au/forums/topic/59521-another-bad-day/#findComment-1140214
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
