My concern is that the rb25det engnies have a massive drop in the torque strating from 3000rpm to 4500/5000rpm and all the manegments just seem to just move the drop or make it more smoother but never can get rid of it.
dude, are you sure you know what your talking about?
Thats the stock ECU causing it. Get an aftermarket ECU... and a decent tuner and that problem just goes away entirely.
No ECU tuned properly will have the problem the stocker ECU has.
Oh, and you can get about 250awkw out of a stock GTR farily easily with an ECU
Well a locally delivered WRX is detuned for aussie fuel, only has 195kw as compared to the Jap version that has 206kw. (Same as factory GTR)
So the GTR still has a minor power advantage.
I would say a stock GTR (in good health) would easily give an STI a run for its money.
dont forget that the "206" was on paper :cheers:
The realities are a bit different.
And the "power" advantage on paper is easily written off by a weight difference.
Dnot forget the cars your comparing are a few years apart also so its no very fair to let 5-10years of development come into it
R31Nismoid
Well for as long as i have been around i have never seen a r33/r34 rb25det with a straight up torgue graph, all of them have had a slight dee crease, im good friends with the tuner at hybrid, so far we couldnt get rid of it with any ecu (pfc,emanage ect) and it is the same with many tuners he knows. Look around i think u will be supprised.
Ive seen an sti totaly eat r33 gtr with exhaust, the sti had only had a front mount intercooler and exahust, no bull Shit but the sti really hammerd it buy far, i think both of them were boosted, i saw this on a street run i was behind them wen it happend.
im guessing the sti is not that easy to beet ?
Dizzo
With 217rwkw, do you get chopped by 180sx??? They are lighter so wouldn't need as much power to keep up.
i only have been choped once by a 180sx wen my car was stock as a rock, now with the new setup ive only raced about 2 and only one came close but was still behind buy a car length wen we hit 3rd gear, not sure of the setup it had but a saw a fmic, exhaust and boost gauge. Other was a hightway battle with i won buy far.
:cheers:
haveing a FMIC it would have been boost more than the GTR
the GTR with FMIC would b a different story.
i think i wouldnt be surprised.
considering i own a car with an RB25DET, and a PFC and its got no "hole"
and ive got one laggy turbo too
Its easy to get into the argument where you are comparing variable situations as defined already in this thread. If you want real facts look at the times that people run in these cars.
I ran 12.5 sec @ 111-112 mph in a GT-R with standard turbos low boost etc, usual bolt ons. If you can find a STi which runs consistent times like that in street trim then you've got the grounding of fact to say yes, STi is a quick car. Either way there is no doubt the both of them are quick street car.
That could be extended to your R33 as well. But as I've already mentioned, don't get a GT-R unless you're prepared to go the long haul with it - parts are expensive and parts often fail especially in the older R32s. If you want a well rounded stock car a STi would be a good performer, but to me it sounds like you're happy with your R33.
R31Nismoid
Could it be my tunner ? cause we allways have that little dip uneven slide in the torque.
R31 Nismoid is it possible to see ur dyno sheet to see the torque, i would be very intersted to see it as ive never come accross one without the dip?
Please correct me if im wrong here but ive come to a conclusion that both gtr and sti are verry powerfull cars in there own ways and both cars can be quicker then each other ?? :headspin:
" to bad my gtst cant keep up :Oops: "
thanks for all the replys  :)
I also was wondering how would a compleatly stock gtr compare to an WRX Sti
i was in one the other day and its very very impressive power, pulls and pulls
I have owned ( only sold it 2 months ago ) a version 6 sti (00 , old shape , lighter than new shape ) . I had a power f/c , cold air intake into stock airbox , water spray on the stock top mount cooler and 1.1 bar boost , everything else stock .
It ran 12.6 @ 111 mph @ wsid tree times the same night with traction problems ( to much wheel spin ) .
A bog stock v6 sti will be around 13.5 1/4 , a r33 gtr will be about the same maybe 13.3-13.4 so not much difference .
My r33 gtr with n1 turbos , power f/c + ebc 1.2 bar boost, every thing else stock does 11.7 @ 121 mph , so you can see the potential of the gtr with mods you can get it much quicker than sti .
For the money the sti is a very good package , its half price , if not less , to what a gtr is for the same age .
R32 gtrs are getting a little old now so you must be prepared to do some work on them but they are a lot of fun to drive
i think stock vs stock the GTR would be the go versus the STi, my preference anyway
does anyone know what you can screw the boost up to in an STi before having to do any internal work ? ( i dont even know what turbo it runs )
the GTR has a race car feel that is pretty awesome, plus attessa - wich gets a Huge tick in my book.
what are you after in a car ? straigh line power or twisty fun ?
i think the cheaper option would be to stick with ur 33 and get some handling bits, check out the handling pack from whiteline, thats what im looking at. not sure what ur suspension setup is like at the mo but i reakon the 33 gts-t can be quite a tight unit on the track with the right suspension setup - and u can always go for a bit more power with some more mods.
wylie i think stock vs stock the GTR would be the go versus the STi, my preference anyway
My main concern is that my car is not awd, it wories me that awd will always be faster. :)
We had a track day on the "Clubman" track at Queensland Raceway recently and the R33 GTR ate everything including an AC Cobra. There were also some STI's there. I had a speed trap setup on the straight and the Cobra had it all over everything, but as far as the lap times went the GTR was the machine of the day. Oh yea, and it had stock turbo's that were high flowed and some boost and that was about it.
I think when you are talking GTR's its the race track that matters not the drag strip. Anyone in a tubbed out big block Torana can go fast at the drags, putting in fast consistent laps at the track is another story.
not to bag people, but more than likely it is.
I dont have a dyno sheet ATM the one i had went missing. But i can assure you my curve just keeps climbing up and up
:P
Yep on the highway you have more power so you'd have a higher top speed, ie the faster you go the more power becomes a factor over weight difference.
Did that 180 with a front mount, exhaust and boost gauge beat you to 100km/hr though?
Dizzo
No, he was behind me all the time.
The 180sx is light but to get similar power to a skyline they need to be runing much higher boost levels. Skyline can run half the boost level and still have slightly more power.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
