Hi Guyz,
I have an R34 non turbo. I am currently looking to get more power out of my NEO RB25DE. What would be the best way to do this? Should i do a turbo conversion or should i go all motor.
How much power can i get if I go N/A? What mods can i do.
is it worth doing a turbo conversion?
Im not really interested in changing the motor at this stage.
https://www.sau.com.au/forums/topic/59528-na-power/
It's your choice on what you choose to do with your car, each has it's advantages, but if you are after power turbo is the way to go.
I'm luckly enough to own 2 skylines one turbo and the other N/A. Believe it or not I prefer my N/A over my turbo, even though it's not as fast.
Things you can do to help improve the power of an N/A car are high flow air filter either the likes of a HKS panel or K&N panel or a pod filter with a cold air box, extractors, 2 1/2" exhaust system, apexi safc to control the air fuel ratios, or even a Greaddy emanage, these will get the car going nicely and will improve mid range and top end power. You can get more power out of a N/A, but after the mods I have sugested things start getting more expensive and the gains are pretty small for the amount of money you spend.
https://www.sau.com.au/forums/topic/59528-na-power/#findComment-1136843
