Wheel clamps are definitely a problem now, but as mentioned above, it's nothing an angle grinder can't fix :) I'm sure a few of us would be willing to pitch in if someone were stuck.
I think most of us have had bad experiences with parking inspectors around the CBD and northbridge. Driving our cars will nearly always attract the inspector with even more of an attitude.
I recently had an issue in perth where I had parked in a 15min spot on king street and the a**hole began screaming abuse (progressively getting louder) at me once he saw me unlock my car and then continued printing his ticket. I didn't bother giving him the satisfaction of an argument, I just jumped in and drove off and never ended up receiving any mail regarding the issue or being reminded for payment of any kind/amount by fines enforcement.
The fact is nearly all of these guys are so depressed with their own lives working a shitty job they hate because they have no f*cking direction in life or the inclination to do anything worthwhile with their time, they find the need to inconvenience people with real lives and jobs :)
:werd: :werd:
If i could get the smiley "werd" to work i would have put it here Jengus... well said, of pure boredom in their general job when someone is out of line they reallly snap at them even for being 5 mins overparked...
i guess if you picture yourself being a garbage cleaner.... if someone threw litter down on the ground you would want to rip their head off! i guess it relates to job specificity...... just petty things can set them off in their boring job.
thing is u dont want your wheels clamped
im not sure why they put a fine on some cars and clamp others in the same carpark maybe they run out of wheel clamps or they put the fine on and clamp you later?
When u get a fine initially they take your rego, and when they go round checking cars, if they have taken your rego previously, and you have fines outstanding, they clamp you.
Apparently people have been trying to shut down the clamping through legal means with no success (i think they have some influential people connected to them), especially seeing that similar attempts in the east have been successfull in the eastern states...
Umm nothing can really be done if it's in a private car park, that is it just costs to bloody much for them to enforce it.
There is the wheel clamping thing. Now to get around this you cut the padlock off and REPLACE it. No criminal damages done.
If anyone can find a precedent for this in WA I'd love to hear it.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
