Hey, i have a basically stock R32 GTR..
full exhuast with front pipes..
impul modded stock ecu.. no idea to what extent..
aftermarket airfilters..
i have just purchased some R34 GTr N1 turbos..
My plans were to get a Boost Controller straight away... EVC 5 probably ?? good ??
and what do you think i should do next.. im on a limited budget but i want to get maximium performance and realiability for minimal cost..
thanks people..
these what i was thinking.. whats your thoughts wouldnt come at once but would they be wise??
HKS Cams 265 in and out ? sound right?
Power FC
Nismo AFMS ?? cost $$???
cam gears ??
Bosch 044??
Front Mount?? hopefully a trust one ??
injectors 600cc??
thanks heaps!
get those N1's on there make sure before you do that you can afford a set of nice aftermarket dump pipes and bolt them up at the same time as the turbo swap. Other then that I would be looking at installing a pfc and cam gears and looking for a good tuner .
Shouldn't have to worry to much about your afm's if you keep it under 300kw@wheels if you want to go close or more you will have to upgrade your fuel system as well .
i think it would be better to go for a AVCR with the POWER FC. with the afm's you could use 2x rb20 ones. you can use the standard cooler upto 300kw so i wouldn't worry about it for now. then i would go for fuel pump ( bosch, walbro or nismo, probably one of the other two to keep cost down) and injectors ( 600cc sounds good ). as GTRman1992 said an oil cooler would be a good investment if you intend on going to some track days. sounds like you going to have some fun on this project!!! :D i would ;)
great Question Kill HSV!!! yeah i was planning to do a compression test before the turbos go on if all good will put them on if not oh well.. will just have to rebuilt it i guess.. or save for one!! anyone else know much about the differences between avcr and Evc5 ??
