Personally I think they are a waste, as I seem to make up time on gearchanges compaired to others with short shifters... (I dont have one). Sure they are nice and all, but I just think the money is better spent elsewhere (going in to a new gearbox maybe :rofl:)
Short shifters are a great concept., however, I do not trust the coordination of my clutch and shift work enough to justify one. I've seen many people **** their syncro's with them. Like sydneykid said, it is driver error.. but the longer pivot only contributes to driver error.
They will mess things up sooner or later - no one can shift perfectly, nor have perfect clutch timing.
Alot of Honda guys have notchy transmissions caused by short shifters. Most often it's the ITR's with their stock short throws. At first, the short shifter seems amazing, and over time the transmission becomes alot more edgy and temperamental. I've expirimented and formed my own opinions on them with my experiences using them in my own cars and friends cars - the outcome is always the same.
Me = against short shifters.
I just change my shifter to C's original short shifter, it's smoother than original shifter and it's much shorther.
I did everything by myself , there is no dramas at all, instruction says everything clearly.
It took me 40 minutes to install (I'm a noob :rofl: )
Erik
dude are you the guy who bought frankys car ???
Also can you PM details on where you got your original Cs shifter for your car..
been looking for one for awhile and people say that the Cs factory went bankrupt and you cant get them anymore...and I dont wanna get a copy.
A little OT but I have installed a short shift (copy of C's or some home brand type) - it's a solid brass one and I don't see it snapping or anything and it really does make the box feel a LOT nicer. Unfortunately sometimes the stick itself gets too hot to touch (which makes quick gear changes a must and stops you from resting your hand on the shifter heh heh)
Just one question - how do you tell if you're going too fast for the syncro?
you'll be able to tell if your shifting to fast for the syncro's by ear and by feel. More so with the short shifter, as you'll have more feel. Basicaly if you have to force it your going to fast. you can still change gears fast and be gental at the same time.
It may take a bit of time to get used to the feel, but you'll know when you do get the change right.
I'm a bit worried about the heat getting through the shifter though. the only time 've ever seen a hot gear stick is when its got a metal knob and its out in the sun. It surtainly shouldnt get to hot to touch just from driving.
i was going to cut my shifter down 2 inches and then get a mate who is a machinist to re-thread the end of it to put gear knob back on.
will this be any different than buying a short shift kit?
carro
Cutting your shifter will only make the lever shorter not your shift. Thats why they are called short shifter and not mini gear stick. :D
Read what sydneykid wrote a few posts back and it will help answer your question.
Does anyone know the difference between a shifter for RB25 and RB20?
Can you fit a RB20 short shifter in a RB25 box?
The fool who sold me the crappy shifter is trying to tell me that there is no difference and only the bolt lengths are different?
I have a RB25det box and RB20det box side by side with shifters.The RB20 one fits the RB25 one fine except that little nylon bush at the end is way to small (read like half the size!) and is very sloppy.
Yeh they fit but they dont work properly and they make a shitload of noise
Occassionaly it would pop out of the selector in the box and over time it would probably stuff up. No good if you want reliability and safety or control.
A picture showing the comparison between the no name short shifter and the standard shifter;
I can confirm that the no name shifter is 16mm longer from the pivot point to the point of engagement with the linkage than the standard shifter. It is 58 mm and the standard shifter is 42mm. The gearlevers are the same length from the pivot point to the knob, being 210 mm. So this means a 20% reduction in gearknob movement for the same amount of shift linkage movement. That was what was advertised and it does in fact achieve a 20% reduction in shift movement.
There is another benefit I overlooked previously. The 16mm spacer under the pivot point moves the shift up wards, and since it si the same length above the pivot, thsi means the gear knob is 16 higher in the car. Hence 16mm closer to the steering wheel, which means less time spent moving the hand from the wheel to the knob when changing gear.
This is of course exactly the opposite to what would occure if you simply cut the shifter and moved the gear knob lower down on the shaft.
Dissadvantages/advantages that I can see when comparing the standard to short shifter;
1. There is no rubber isolation of the top half of the shifter from the bottom half (that's what the bulb is half way up to the knob). This means there will be more vibration passed to the gear knob. On the other hand it means better feel as there is no rubber dampening between the gearbox and your hand.
2. The lack of rubber insolation measn that the heat from the gearbox will pass up the metal lever all the way to the knob. This no name shifter came with a chrome plated gear knob, which will get hotter than the standard gear knob. If this becomes an issue I may try a plastic washer and some teflon tap on the thread to isolate the gear knob from the shift. That may stop some of the heat transfer.
Hope that was of some use.:cheers:
PS; thanks to gR33ddy for supplying the standard shifter used in this comparison.
carro
Yeah. it will be different. a short shifter kit works by shifting the pivot point higher on the stick, making the length below the pivot ball longer. ther installed length of the shifter is not nessasarily any different. It's the actual ratio of the gear stick throw that is diferent. as an example mine is 12mm longer bellow the pivot point than the standard stick. So for a given movement of the gear lever the lower end of the gear stick moves further than when it was standard.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
